Results 1 to 13 of 17
08-12-2012, 12:08 PM #1
- Aug 2011
- Salem Oregon
- 26
Inside a pipe brazed with nitrogen
08-12-2012, 04:22 PM #2
- Feb 2011
- Orange County, in a Galaxy far far away...
- 237
This is exactly the reason why I use a flowmeter, 3 psi is all it takes for a couple of minutes and it'll save a call back later when drier's plugged or worse...
You cannot cheat an honest man. But that doesn't stop people trying!
08-12-2012, 05:13 PM #3
Sweet pic for sure!
I'd like to see the same shot but without nitrogen being purged through.
Probably be a cool side by side comparison to show non believers.
08-12-2012, 06:38 PM #4
- Aug 2011
- Salem Oregon
- 26
08-13-2012, 09:53 PM #5
- Mar 2005
- 54
08-13-2012, 10:55 PM #6
08-12-2012, 05:49 PM #7
Without nitrogen it looks the same as the outside of the pipe. In school my teacher had us do all types of brazing and soldering then cut our joints down the middle to check penetration and heat control. You could tell who used nitrogen and who didn't.
08-12-2012, 08:30 PM #8
I mean like on some scrap in some spare time
08-12-2012, 11:39 PM #9
- Aug 2011
- Salem Oregon
- 26
good point
08-21-2012, 11:22 PM #10
Awesome pic man... I remember learning about this is school, must admit I have never done it... ;/
08-22-2012, 04:03 PM #11
- Apr 2005
- nyc
- 20
The flow rate for pruging with nitrogen is 3-5 CFH----That's cubic feet per hour-----which is not alot of nitrogen. I usually go 10CFH.
08-23-2012, 08:39 AM #12
- Aug 2011
- Salem Oregon
- 26
How do you measure/calculate the CFH you are using? Is it the same flow rate for different pipe sizes?
I always just put 2 or 4 psi on the gauge. That puts more CFH in a larger pipe than a smaller one.
08-23-2012, 09:23 AM #13
- Apr 2005
- nyc
- 20
Flow meters can be purchased at any welding supply house........you'll save a ton of money on nitrogen. As far as the flow rate for different size pipes, I would assume the larger the pipe the more flow you would need. The correct procedure is to put an oxygen sensor at the end of the pipe and when you 0% oxygen you start brazing. Oxygen sensors can be quite expensive though.
