Results 1 to 13 of 28
    PISSED OFF at Carrier
    I had installed a new Carrier comfort series 2.5 ton heat pump system from a local rep hvac company. model#25HCB3, AHU#FX4D on 6/28/2010. yesterday the fan motor died. I had to pay $ dollars in fees and labor. is this going to happen every 2 years? I emailed Carrier my thoughts and how I should get my $ dollars back. anyone have any thoughts? I think the warranty is 5 years. thanks.
    St. Augustine, Florida
    there are two warranties......LABOR and PARTS. This is usually illuminated on your sales sheet or invoice. Very rarely do people buy a LABOR warranty. Carrier doesn't pay us to fix it unless you buy it. In the WalmartWorld of price shopping things get really lean sometimes and contractors have to cover costs of operation. Money doesn't fall off trees into our offices, we bill customers. That is how it works. When you buy a car, you help build all those fancy dealerships we drive by......
    Hell, Carrier and others sometimes bill us a processing fee for big warranty parts. Guess who ultimately pays that? You do.
    Sorry your motor broke.
    Lancaster PA
    You apparently have a part only warranty. Didn't your contractor offer you the extended labor warranty. If not, you should let him know that you would have bought it if he had offered it to you.
    Its not Carrier screw up that you had to pay, its your contractor that didn't tell you about extended labor warranties.
    Your contractor did not build the unit he just installed it,some contractors give a 2 year warranty some give a 1 yr and some give a30 day on installs
    Jul 2010
    nebraska
    If the duct work is sized correctly and you keep the filter clean it shouldn't lose another motor. A tip... those 1" pleated filters that say "last up to 3 months" are usually in need of changing after 30-45 days.
    I am sorry Beenthere, you are totally wrong! this is Carrier's product. they SCREWED UP!!!!
    I had a 1 year labor warranty through the contractor. The contractors installer told me he had to replace a bunch of these motors. so the motors coming from Carrier are defective.
    Jul 2010
    nebraska
    Have your installer check the system static pressure. Most furnaces state max external static pressure .5". If it's more than that then it's not the motors or Carriers fault .
    Jul 2005
    Quote Originally Posted by mrestfla View Post
    Carrier didn't build the motors, they bought them from Genteq (Emerson). If Carrier is responsible, then so is the installing contractor for the same reasons, and even the distributor that sold the unit to the contractor. Where do you draw the line? IMO the responsible party is the manufacturer of the shoddy part. OTOH, the part was warrantied. Labor costs are unfortunatly yours, since you own the equipment. As owner you took on that responsibility. Caveat Emptor.
    Ask your installer to give you the TESP number, and let us know what that is
    Delaware
    If you had a one year labor warranty, and you installed the system on 6/28/10 as you state in your first post, is not the labor warranty elapsed? What year is it?
    Always here
    Mar 2009
    Mount Holly, NC
    which motor died? the fan motor outside, or the blower motor inside?
    I'm always leery of contractors that tell me "I've had many of these motors fail, xxoo company got a bad batch!" do you have any pictures of the installation? if it's the "fan" motor outside, has the system been cleaned in the 2+ years since the unit was installed? if it's the "blower" motor inside, what kind of filters are you using? what size and how many are on the house?
    thanks for the info, I'd like to get to the bottom of the problem for ya.
    also note, that capacitors made in china are often the problem with failed motors... and we have little recourse with this problem...
    The three big summer hearththrobs...
    Mel Gibson
    Dwane Johnson
    The A/C repairman
    Houston,Tx.
    There are literally thousands of mfg. products a year that fail, because of a part they used in their product manufactured by someone else, this is the way it is and has been for decades. My guess is if Carrier had enough failures due to a faulty part they would have a recall or compensate you for the labor, I know this happens, Ruud did it with their boards back in the early 90's. All the Pro's here stress to the home owners all the time to buy the best parts and labor warranty, there really cheap compared to a repair, I bet what you paid for labor, you could have bought a 10 year P&L warranty. In my opinion, your service tech was wrong mentioning he has replaced a bunch of these motors, how do you know he is telling the truth, did he have documentation? If your SUV flips and gets totaled because of a faulty tire, do you blame GM or Goodyear?
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Lancaster PA
    And Carrier gave you a "5 Year Limited Part Warranty". Limited to the part only. They stood behind the motor.
    If your contractor had to replace a lot of those motors. Sounds like maybe they are doing something wrong.
    Now would be a good time to have the systems static/TESP checked, before that new motor goes out again in another 2 years.
