Results 1 to 4 of 4
    All over the western U.S.
    Confused Can you convert a Hotshot A/C to R22 ?
    Hi all,
    Long time lurker here & some of you guys/gals have great insight and have been doing this gig longer than I. I finnaly came across a pre-historic 40 ton double-duct / hot & cold deck, air-cooled built up system from i think the 1970's, it serves a big retail store..anyway it used to be R12 but someone converted it to "Hotshot". I was just wondering if any of you all ever converted out of Hotshot into something else like R22? I may need to replace the evaporator( it's around 40 yrs. old & may be leaking ) and condensor. I'd like to maybe keep the Hotshot because there is over 200lbs. of it in this system.
    Apr 2003
    Maple Grove, MN
    200 pounds of r22 would be expensive (as would a new evaporator and condenser). You would most likely need a different compressor and expansion valves too. Does the system work right now? Does the hot deck / cold deck work? What shape are the controls in? Is the system worth trying to restore, or might it be better to abandon it and start over with a rooftop unit or something else?
    I figured new TEV's and some old control replacement for sure and I'll check with Carrier if the comp will work. System has a lot misc. unrelated breakdowns, like I said it's all very old. The decks do work. I'll try to restore the system because the flimsy roof can't handle much more than a spread out built-up system.
    Actually right now hot shot is cheaper than r22!!
