Results 1 to 10 of 10
    Jul 2012
    Thermostat power
    In the year I've owned my house, I've had to replace the upstairs t-stat batteries about 4 times, and never the downstairs. This spoke to me that it was either something wrong with the actual control unit, or the HVAC power wire? Recently it gave me a "bat lo" message in the middle of the night, shutting off the A/C and waking me up. I shook it and it resumed normal operation.
    Is there a simple way to test if it's either the unit or wiring? Is it as simple as taking a voltmeter to the wire? What voltage should I be looking for? Sorry if this seems DIY, I just don't have a good understanding about how t-stats are powered and what I should be looking for.
    The t-stats for both downstairs and upstairs are Honeywell programmables, at least 12 yrs old.
    Frederick, MD
    Quote Originally Posted by Johnnyma45 View Post
    Yes, this is DIY and any replies regarding troubleshooting are against the rules. Sorry.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    Jun 2009
    Upstate SC
    Are you using cheap batteries?
    Jul 2012
    No, Duracells AAs.
    Jun 2009
    Upstate SC
    Has your problem just recently started occuring? You mention the stats are 12 years old.
    Jul 2012
    I've only owned my house for a year, but the t-stats are from when it was built (2000). It's been happening on and off over this last year - it seems to drain the batteries in the upstairs unit and the bottom one has been fine. So I guess to rephrase my question, away from DIY is, how are thermostats powered? Is it primary battery with HVAC power backup or vice versa?
    Philadelphia, PA
    Depends on the model thermostat, and how it is wired. Some are battery powered only, some are either battery or hardwired, and some are system powered with or without battery backup.
    Oct 2007
    Austin Texas
    It also could be as simple as the upstairs t-stat cycles many more times than the lower one.
    Nemo me impune lacessit.
    Jul 2012
    Quote Originally Posted by John Culpepper View Post
    ...did not consider that, but it makes sense. That would imply that it is battery powered primarily...I'll have to check the model number and do some research. Thanks all!
    Jun 2001
    Consider upgrading to a system powered digital thermostat. These aren't sold at the big box stores and require a common wire connection so you will need a pro to hook it up for you. IMHO all digital stats should be common wire powered, but unfortunately most builders are cheap and use the battery powered stats.
