Results 14 to 26 of 27
Thread: Disconect
    North carolina
    Thanks for all the answers i didn't think there was much repair work that could be done to it other than checking for tight connections and i did that. and yes it is the cheap grey resi non fused pull out type not to be confused with the lever type pictured a few post back
    Mar 2012
    New Hampshire
    Whenever an electrical component is proven faulty, just replace it. Its safer for everyone involved and you can sleep well at night. We only install the disconnects with the GFI outlets on them (single phase residential) it makes life much easier in the future.
    May 2011
    Oklahoma
    Can someone link the disconnects with the gfci in it? I've never seen one I don't think.
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by matt1124 View Post
    I don't think I have ever seen one either. How are the outlets wired up? Do you have to pull a separate neutral and hot wire from the breaker panel to make them work?
    Is an outlet required near the condensing unit on residential stuff per code? I know that they are required for commercial roof-top units, but am not sure about residential.
    Nov 2011
    St. Louis
    Quote Originally Posted by shaworth1 View Post
    always replace a suspected faulty disconnect, there not that expensive and the homeowner deserves as safe a system as possible.
    A few blocks away a very reputable contractor put in a shiny new Bryant with the existing disconnect. A few days later the HO heard a small explosion and came out to see the disconnect on fire and melting the siding. Now if I see any rust on the lugs or other problems on an install I'll change them even if the shop has to send one over.
    I don't need to be thinking about a questionable disconnect as I'm trying to drift of to sleep.
    Apr 2012
    I've ran into a disconnect that was 3 phase 240v 60amp that the bar inside was loose. It would only energize L3 and it was missing a metal piece to make the bar push up L1 and 2. I just replaced it didn't want another tech dying from L1 and 2 staying energized.
    Southeastern Pa
    In my pic above, only the A phase is connected to the bar...
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Virginia
    Most disconnects i find bad are connected to aluminum wire with no goo on it
    Mar 2012
    New Hampshire
    Quote Originally Posted by ammoniadog View Post
    I can't remember the mfg, I will find out tomorrow and post a pic. It's looks like a regular pull style disconnect just with an GFI outlet beneath it.
    Quote Originally Posted by Tony3696 View Post
    http://www.amazon.com/Siemens-WN2060...ect+Gfci+Panel
    Cincinnati, Oh
    NEC requires a outlet with 20', on new installations/relocations. Not replacements.
    We've "attempted" to install one we had at the shop. Bossman claims it works, using the 220v.
    Which, it doesn't. On those disconnects, you must run 2 circuits. One for 220v, one for 110v. Unless you try and hack it in and put neutral to ground.
    Just pray you don't become a shorter path to ground when you plug in.
    Or that you pull higher than 15 amps, and it catches fire because it's protected by the breaker sized for the A/C, not the outlet.
    The reason they make them, is so you don't have to mount a seperate outdoor rated recepticle box.
    "Just get it done son."
    Dad adjusted
    May 2011
    Oklahoma
    I figured that's what it was. You'd either have to be lucky enough to find a neutral capped off in the existing disconnect or run new wire. "Siemens - for when the lowest bid gets the job!"
    Massachusetts
    Here's one I just recently replaced.
    Sent from my PC36100 using Tapatalk 2
