    Oct 2010
    XL15C and command display
    Have a job that the command display is linked to xl15c, but what would seem relavent setpoints like changeover/room setpoint arent programmed (stuff is standalone).The command display is only showing status/room temps etc.Is there a way to create setpoints in the display and map them to the xl15.
    Dec 2006
    Boston area
    No you need to use a configuration tool, Lonspec, to configure command display. You can download it free off Honeywell Buildings Forum but you will need a Lon adapter for your PC.
    Jan 2005
    Quote Originally Posted by mechmike2 View Post
    Exactly. I wouldnt attempt it if you are unfamiliar with the workings of lonspec unless you have some time to learn it. Its not a complicated program but you wouldnt want to mess the site up either.
    "It's always controls"
