Results 1 to 13 of 14
    Tampa Bay, FL.
    Fieldpiece SMAN3 trouble
    Just got my sman3 two weeks ago. Left it on a vacuum overnight and had no reading this morning. Reconnected it finally got a readout. This pic was while the pump was running and was in a deep vacuum. Anyone else experience this? Right now it's gone from my new favorite toy to the not to be trusted list!Name:  ImageUploadedByTapatalk1344697451.474860.jpg
    Jan 2006
    Hamilton Ontario Canada
    Looks like it is sucking air on the high side. Check all hoses and connections ?
    Jan 2006
    Did pressure test hold?
    Tampa Bay, FL.
    Checked all the connections and when I restarted the vacuum pump, there was nothing to evacuate. System was still in a deep vacuum but the gauges indicated otherwise. Very strange.
    Jul 2012
    Call Back fieldpiece inform them of ypur problem.
    I had a leak on my sight glass. Fieldpiece will work you. I love these guages.
    Quote Originally Posted by ptemko View Post
    NW burbs of Detroit
    if you didn't use vacuum rated hoses, it ain't gonna hold.
    Tampa Bay, FL.
    That's what was weird. It was in a hard vacuum and you could tell from the sound of the pump that it was but the gauge said otherwise. Gonna play with it more this weekend. Don't have time to test out equipment on the job. I'll stick to analog until I determine if that was a fluke or not.
    NW burbs of Detroit
    not to contradict you, but pump sound does not tell you how deep you are.
    that's an old school method I used before Got my micron gauge.
    Tampa Bay, FL.
    I agree with you but the difference between 500 microns and 6000 microns should be audible. I have a freebie project freezer that I fixed the leak and put on nitro last night. Looks like its holding so I will evacuate it today and see what my gauge reads this time.
    Apr 2010
    Minnesota
    What does it do if you plug your hoses and hook it up to the vac pump?
    With both hi & lo side open pressure up with some nitrogen and watch to see if both transducers read the same as you fill it up. One of my coworkers had a bad transducer on his.
    Tampa Bay, FL.
    It seems to be working fine now. I haven't been able to duplicate the problem so I'm gonna chalk it up to user error. but it was weird.
    NW burbs of Detroit
    Quote Originally Posted by hydra View Post
    If you are just starting out with any digital, the data on the screen will confuse you.
    Case in point:Working on my son's in laws ac. Put my Testo 557 on it and the SH read..... which mean it was "zero" sh.
    SMAN can do that to you too. My SC clamp was reading nothing...switched it with the SH clamp and got a reading. Prob was I didn't push the SC plug all the way in and it had a little smear of refer oil on it too... bad contact.
    You'll be in for a few more surprises as you go along. Nothing wrong with the manifold, just a few mistakes the operator make.
    Jan 2012
    Fresno, ca
    The micron gauge is in the center port. You need to have one valve on the manifold open to the system and have a valve between the center port and the vacuum pump closed in order to isolate the micron gauge and the system at the same time. hope this helps...
