Results 14 to 21 of 21
    Oct 2012
    Wisconsin
    Quote Originally Posted by hydra View Post
    I used to try and explain it to them but it's like talking to a brick wall and when I go to the back and see the worn out breaker panel feeding everything I just give up. One time I was recovering refrigerant from a burn out and my recovery unit was bouncing all over the floor. After some investigation I discovered that the outlet the equipment was on and I was using had 240 volts going to a 110 outlet!
    I've run into that a couple times where there is 240 on a 110 outlet. Sometimes I get paranoid, and check the outlet with my meter before I plug into it.
    Oct 2009
    Bran nu, all gotee UL tag!.
    Never argue with a crazy man.
    AZ
    If the breaker pops, just put in a bigger one!
    Tampa Bay, FL.
    Quote Originally Posted by dijit View Post
    That's the logic I run into frequently. It's amazing how many people have no clue about electricity at all!
    Rochester NY
    Thermal image camera, or even inexpensive temp gun, can be used to cure ignorance.
    Probably ain't gonna fix stupid, but you can fix ignorance.
    i think it is okay!
    he used the little adapter so there is no more earth ground!
    now he can not get shocked!!!!!!!!!!!
    maple ridge, bc
    Terrible, someone might trip.
    Central VA
    Quote Originally Posted by anthonyac1 View Post
    at night the rat huddles close to stay warm in the wiring, kind of like a drain line heater,but once he gets to close he literally gets the **** shocked out of him!!! hahaha
    That's right, why is everyone being so hard on the store workers? They are just trying to take care of their guests! PETA compliant!
