Results 1 to 13 of 21
    Tampa Bay, FL.
    I don't know why my store burnt down!
Size:  77.0 KB each of these plugs are attached to 1/3 hp coolers. Where's the Fire Marshal when you need him?
    Jun 2012
    San Francisco Bay Area
    Looks up to code to me
    Jun 2012
    Northern NV
    Warm to the touch? I think I see two 16ga extensions feeding 2 coolers each? How long are the cords? Why is the floor clean and where did the dust bunnies go?
    We all know this is not the best installation. We also all know that these are hiding out behind equipment at too many ma and pa convenience stores, so I just do a quick "hands-on" and if I can hold on for an extended time, I just let the owner know that this is a hazard on his ticket and leave. If it is smokin' hot we have a meet-with-vishnu moment.
    Tampa Bay, FL.
    I used to try and explain it to them but it's like talking to a brick wall and when I go to the back and see the worn out breaker panel feeding everything I just give up. One time I was recovering refrigerant from a burn out and my recovery unit was bouncing all over the floor. After some investigation I discovered that the outlet the equipment was on and I was using had 240 volts going to a 110 outlet!
    Houston TX
    hydra- I've got one better then yours, I had a building engineer wire a 120 duplex outet with 277 volts so he could test light fixtures and a helper plugged a buffer into it. He pulled the switch and it blew up in his hand. The outlet wasn't marked or any warnings posted.-GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
    Tampa Bay, FL.
    Wow! It's bad enough to do it out of stupidity but doing it on purpose is down right negligent!
    Sep 2012
    I think she's a little overloaded
    Nov 2007
    Mississippi
    That looks like me.........2 vacuum pumps, drop light, battery charger, shop vac, box fan, sawzall, and impact all off one pigtail.
    Tampa Bay, FL.
    Quote Originally Posted by socotech View Post
    Believe it or not, that was a permanent setup at a major chain grocery store! I'm used to seeing it at the mom n pops but this one kinda surprised me.
    Clearwater, FL
    How ridiculous! Can't believe they didn't have the same color wire....how insulting.
    Seriously, is that rat crap all over the floor? problem soon to be solved. Just stick a wire under a trap with Grey Poupon (yeah, the good stuff on they way out)
    Why do I only get a HVAC license when reality is I'm a plumber, electrician, counselor and financial expert once I'm working on someone's equipment?
    Rochester NY
    Quote Originally Posted by primecooler View Post
    Apr 2012
    winnipeg
    that's just wrong....who does these things..... i would walk away
    Sep 2010
    miami,fl.
    Quote Originally Posted by tedkidd View Post
    at night the rat huddles close to stay warm in the wiring, kind of like a drain line heater,but once he gets to close he literally gets the **** shocked out of him!!! hahaha
