Page 7 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 79 to 91 of 211
  1. #79
    Delaware
    Quote Originally Posted by Florida Joy View Post
    OK, this site lists one in my county, two in an adjacent county. However, they all do commercial/institutional work. They'd do mine, if I insisted, for a price... more than I'm willing to spend.
    Did you actually TALK to them? They will be in the house 1/2 hr tops. So they invoice you for an hour. It will be under $ Remember You just want the totals, NOT balancing
    Also, you keep talking about "salesman" You mentioned that the one owner had the company since 1975. Thats fine, but tell him to bring his manager or son with hime next time so you can see deeper into the company. Because he'll (they) will be retired 10 years from now.
    Also you may not think you don't want to talk to a sales rep.....but you have....and your sold on a 4Ton 20 SEER system. Another sales member is not needed, you sold yourself.
    Good luck
    Always here
  2. #80
    Aug 2012
    Florida Space Coast
    Quote Originally Posted by energy star View Post
    Yep, they charge $ a day with a 1 day minimum. He said they do commercial work, not residential. He was surprised that anyone would ask to do a private residence. He said if my ducts were designed for 3.5 tons of airflow, pushing 4 tons wouldn't be any problem. He said all an A/C installer has to do to verify duct capacity is "measure" the size of the ducts and determine if they're lined up the way they should be.
    Both businesses are in the hands of the "sons", but were started by their fathers in 1975/1985.
    Good luck
    Yes, I agree, I pretty much sold myself. But, depending on Manual J calculations yet to come from the winning "bidder", I may talk myself down to the XL20i in a 3 ton. It's not over 'til it's over.
  3. #81
    Prices are not allowed.
  4. #82
    Saint Joseph, MI
    It would be nice to see their Mannual J calculations. Some contractors do the calcs, but are know to use incorrect data. They conservatively estimate insulation, windows, use incorrect shading factors, incorrect desing temperatures, use a conservative air leakage, etc.
    End the end, many customers in hot weather won't like a properly sized system because it run continously and seems like it's maxed out. We most familiar with automobiles. If your design requirement was to go 70mph on flat ground and 0 headwind, and 45mph up a 10% grade and carry 3 passengers and 100lbs of luggage, you'd get a compact car with about a 40HP engine. It will meet those requirements. It will probably also get 40mpg city and 45mpg highway. But that's not ideal for most.
  5. #83
    Aug 2012
    Florida Space Coast
    Ouch, that hurts! Just slapped myself upside my head again. Bad girl!
  6. #84
    Rochester NY
    Lot of assumptions there. First one we already know does not exist. You don't have duct work designed for 3.5 tons of airflow. How?
    Size of return.
    You have a 20X20 return grille, if its a filter return grille, its good for about 1.5 tons of cooling at a velocity of around 380 to 400FPM. So since your return grille is under sized. Why trust that your duct work in the attic is anywhere close to being adequate.
    Think they'd really put 3.5 ton of duct in and be that deficient about the grille? Saving small money on the visible and NOT saving big money on the invisible? Other supporting information - comments about filter, size of house (very unlikely to have 3.5 ton ductwork in that size house.)
    You might be getting 900 cfm at .8 static and just barely not freezing your coil, which explains why humidity is well managed. Adding a return may get you a few cfm, but not enough to make up the deficiency for the additional 1/2 ton. And why take the risk and expense? The 3 ton unit isn't much smaller (your current unit more than carries the load, right?) and you can always further improve the home with the equipment cost savings and energy savings if it turns out 3 days a year it only holds 78f instead of 75f.
    You can go with the 4 ton, but be prepared to replace very expensive ECM blower motors as they burn up in the attempt to deliver 1600 cfm. And don't be surprised when the MFR declines the warranty claim, your duct work is not their fault.
  7. #85
    Aug 2012
    Florida Space Coast
    I'm not concerned with the unit running constantly, so long as it's in stage 1 and saving me energy. What I DON'T want is for it to run constantly in stage 2 to maintain in the heat of the day during summer... which in my neck of the woods is pretty much 11 AM to 8 PM, May through October. Running a 3 ton dual compressor unit at full speed all the time to maintain my daytime comfort level of 75 degrees would tick me off!
  8. #86
    But cost less to operate then a 4 ton going to second stage once or twice an hour for 10 minutes.
  9. #87
    Aug 2012
    Florida Space Coast
    Yes, OK, I can see that. But... will the 3 ton struggle to maintain my 75 degrees so much that I end up unhappy because the temp rises to 78 every afternoon? That's what I'm trying to avoid, while saving energy and reducing strain on the equipment.
    I will have a serious discussion with my contractors about the 3 ton XL20i versus 4 ton for my home, but I still may not be convinced... unless... I could find someone with a similar home in a similar environment that can attest to the efficiency AND comfort of the 3 ton. Anybody got references in your Rolodex I could talk to?
  10. #88
    Jul 2009
    Northeast, Md.
    I have worked for a Trane dealer, and have installed a few 20I systems. Love installing them, but hell with working on them. LOL I personally put a 15i in my home and stayed away from anything 2 stage. Yes this advanced technology is great, but put it in 80% of homes duct work, and its useless. It's like putting Mag wheels on a pinto!
  11. #89
    Arizona
    Here is some info for you. Pay special attention to page four and five.Proper application.pdf
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
  12. #90
    Rochester NY
    Strain the equipment? Cycling is what strains equipment. And wastes energy.
    I was wrong, you aren't getting it.
  13. #91
    Aug 2012
    Florida Space Coast
    Quote Originally Posted by tedkidd View Post
    I get it! I guess I didn't express very well what I was trying to say, so let me revise my comment and say it a different way and see if you follow me.
    I'm all for saving energy and reducing strain on the equipment, BUT what i want to avoid is having the 3 ton struggle to maintain my 75 degrees so that I end up unhappy because the temp rises to 78 (or more) every afternoon.
