Results 14 to 16 of 16
    Rochester NY
    Quote Originally Posted by Juan Madera View Post
    Amazing that you got that "lint brush" so nice and clean. Good job. Took a while, did it?
    My favorite lint to pick out of the Trane/American Standard lint brush is cottonwood fluff.....
    Good work.
    Nov 2011
    New Ulm, MN
    How is the proper way to clean those on a typical "check & clean". Of course I'm Only supposed to spend about 30 minutes at the job unless more time is needed.
    Jun 2007
    I always took off the two ends of a Trane condenser and with a water hose only, cleaned the two ends and just sprayed up the louvers for the other two sides. It got the coil clean enough to work sufficiently.
