Results 1 to 8 of 8
Thread: Trane Estimate
08-09-2012, 11:29 PM #1
- Aug 2012
- 21
Trane Estimate
I just received an estimate to replace the a/c and furnace in my Townhouse, here are the components...
TUD2B060A9362A -- Tran XL80 2-Stage
4TTB3030E1000A -- 2.5 Ton Trane XB13 Condenser
4FXCB036AC3CAA -- 3 Ton Trane XB Series Cased Coil
I can verify the first item on Trane's website, but when I search the 2nd item, I find that it is an American Standard...
the Trane item is #4TTB3030E... Does this make sense? The contractor appears on the up and up, but I'm concerned they are selling me one thing and will install another. The 3rd item I can't find anywhere.
I feel I got a fairly good price on this system, but I was wondering if anyone can tell me if I'd could expect a significant
difference in price (ie, $ and up) if I were to get a quote on a comparable Rheem system. I know I can schedule another estimate, but this is a rental unit and I'm under time constraints... so if I knew I shouldn't expect much savings, then I'll just go with the Trane.
TomLast edited by beenthere; 08-10-2012 at 05:09 AM. Reason: price difference
08-09-2012, 11:44 PM #2
I believe your numbers are incorrect.
Your F on the coil is a "T"
AHRICertificate.pdfMake your expertise uniquely valuable.
08-10-2012, 12:10 AM #3
- Aug 2012
- 21
08-10-2012, 12:11 AM #4
- Aug 2012
- 21
Thanks for the responses...
Does anyone have a thought on whether it's worth getting an estimate on the Rheem?
08-10-2012, 08:06 AM #5
Professional Member*
- Mar 2006
- The South
- 1,841
Rheem is solid equipment, often underrated and overlooked.
Going back to the Trane quote, if not going with a var speed furnace, you might look at the XT80 furnace with the high eff blower.
And you could also get a competitive quote from Trane's sister company, American Standard.
IMO
Good Luck!
08-10-2012, 03:43 PM #6
- Aug 2012
- 21
My Original quote was for the XR80, but there are problems in the townhouse with the upstairs getting significantly hotter than
the downstairs. All the contractors that gave an estimate said a 2-stage would help that problem. And they all said that since this is a rental unit, they wouldn't invest in a VS. The contractor I'm going with gave me the 2-stage for $250 more than the 1-stage, so I went with it... hope it wasn't a mistake.
08-09-2012, 11:50 PM #7
- Aug 2008
- Burlington , Mass
- 442
Trane and American Std are the same company. EX: TUD2Bo60 for trane, AUD2B060 for American std. Not sure but I think the coils and comp units carry the same model numbers. 4* means refrigerant 410A. Just question the contractor, I'm sure it will be OK
I'll be there when I get there and not a minute later
08-10-2012, 08:10 AM #8
Id definitely get an estimate on a Rheem. Once the Trane is out of warranty be prepared to be raped for replacement parts.
