Results 1 to 7 of 7
    Mar 2010
    plano,IL
    Beacon 1 control board
    Had this issue last Firday
    Walk in freezer ( " converted" to walk in cooler) with Beacon 1 set up. came in and found case at 60* going off on hi temp alarm.
    Find coil iced up with about 2" thick ice on back and inside. Go to put into manual defrost and it defrosts for about 8 minutes, fans off no heaters.
    Check relay and no 24dc to coil to cut heaters on.
    I ended up de icing the coil, and installing a paragon time clock in the condesor breaking the contactor to defrost. Cleared the defrost times out of the smart control in the mgrs office. and now it is a regular WIC air defrost and no more issues
    Has anyone found or seen a reason that the control isnt sending control voltage to the relay?
    Oct 2011
    Chicagoland Area
    Yeah, It's a beacon LOL Did you ohm out all your sensors in an ice bath? If I remember correctly 32000 ohm's +/- 10%. I have converted all my beacon 1 units to conventional systems when the boards go bad. Easier and less headaches than upgrading to a beacon 2. Heatcraft can give you that info or I can see if I can find the pdf
    Dec 2011
    Michigan
    We have converted 12 in the last 2 year's. Wish we could just go around and do them all.
    Sent from my amazing 4G device
    Mar 2010
    plano,IL
    The beacon 1 are junk. But to answer your questions 2sac, yes i did ohm out the sensors, one of the first things i do on any beacon system. They were all ok. And I got the pdf from heatcraft last year sometime about the conversion.
    Jun 2011
    wi
    Ke2 therm makes a replacement/retrofit kit for beacon 1. I have done two now and have been very pleased. It is less than half the cost of upgradeing to beacon 2.
    Jul 2011
    Beachwood NJ
    I would be happy to answer any questions you may have about the KE2Therm controller.
    In an infinite universe, not only are all things possible, all things are necessary
    Mar 2010
    plano,IL
    i haven't heard/seen the ke2 and would be interested learning about it. it might be a feasible option for all the B1 systems we have out there
