Results 1 to 13 of 14
Thread: TRANE scrolls
    TRANE scrolls
    I recently purchased and installed 21scroll compressors from mid west TRANE.
    I was told that these are some of the first compressors to come out of the plant in Mexico. I have had two fail and more making noise. Has anyone else had any problems with these compressors?
    In a boiler room
    What is the application they are installed in?
    I packs. New coils, new dryers, of course, completely checked at start up. Weighed charges, amp draws, the whole nine yards.
    Varying tonnage as there are multiple comps per unit.
    I did have a problem with the sight glass seals being leaky and crusty from the factory.
    Might have been an indicator of things to come.
    Stafford, Va. USA
    Hi Dave,
    Did you check the bellyband crankcase heaters?
    The "cornerstone" scrolls must have crankcase heaters.
    If the compressors are getting noisy, it could be refrigerant washing the oil off of the bearings.
    This occurs when one compressor, of a tandem pair, starts and lowers the crankcase pressure of the other compressor.
    The refrigerant is boiled out of the oil and during this process the bearings get the oil washed from the bearings.
    When this compressor starts, the bearings are dry, no lubricate.
    Let us know.
    Good luck,
    Allen
    UA Local 602
    A man who says that he can't learn anything in a class is exactly right.
    Nov 2007
    Mississippi
    Running backwards?
    Quote Originally Posted by Dave at JNB View Post
    I recently purchased and installed 21scroll compressors from mid west TRANE...
    21? how many units do you have? how many compressors?
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Nov 2005
    Oh yeah! I just had one die. There are so many warranty claims on the 15 ton scrolls I won't see mine till mid September. El garbage
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    May 2011
    Oklahoma
    I too am having issues with large tonnage Trane scrolls. Looks like 3 so far this summer on the 15 ton.
    Jul 2012
    Southwest
    I dont prefer Trane compressors. Thats the nice way to say it. There could be more to this, acid, burnouts, txv, etc.
    May 2011
    Oklahoma
    Two were just locked up solid, in warranty. Haven't got to mess with the 3rd yet, other than disconnecting it.
    In a boiler room
    What does the SSH run? What about discharge temp?
