    Indianapolis
    Trane Vari Trac Indianapolis
    Does anyone know who can work on or know anything about the Trane Vari trac comfort system?? The system was put in in 1993. 5 ton and a 10 ton system?? I am renting a building and this is they system it has. The only thing it will do is run the fan. There is no " T-Stat" if there is it is a Honeywell 50-04466-008 ( It does not look like a normal T-Stat ) just says call for service Help!!!
    [Edited by nascar389 on 09-06-2006 at 11:11 AM]
    Jun 2001
    Louisville, KY
    Call Indiana Supply. They can recommend a contractor.
    Real Mechanical, 846-9299. Cool Ed could help you!
