    Polar Pak Self-Contained Refrigeration harmful position?
    Want to start off by saying I am thankful to have found this community and in advance thank you all for any help and insight offered.
    I recently purchase a used Polar-Pak walk-in freezer. It had been turned off for about 6 monthes before they sold it to me.
    Right now I have the Self-contained Refrigeration sitting on its side for the past 2 days. The refrigeration tech who came to take a look today said its harmful to keep it in that position as the oil flows down into the fan (or fan area). As you can tell, I dont know anything about mechanics or refrigeration and I appricaite the patience.
    He said that once we assemble it tomorrow, to not run it for a few days so the oil can go back down. I included some pictures to give a better idea.
    Is the unit still safe and are there any negative reprocussions of keeping it in an altered position like this?
    Thank you for the help and I know this must be a very silly question.
    Click image for larger version.
Name:	20120808_154748 - Copy.jpg
ID:	298791Click image for larger version.
Name:	20120808_154847 - Copy.jpg
    Southeastern Pa
    You can't run a machine in a position other than intended by the manufacturer. I would put it in the designed use orientation for 48 hours before plugging it in.
    Jul 2012
    Western KY
    It should be fine. Get it set rite and let it sit for a day or so and fire it up. Oil will find its way home if charge is good.
