Results 1 to 4 of 4
    Aug 2008
    MD
    Would it be OK to use foam here?
    Hi all,
    I caught a mouse inside my home and was looking to seal openings outside.
    Looks like where my line set, power and control line is coming out has a big gap. It goes up about 4 inches
    behind the deck board as well. I also feel cold air coming out around the opening!
    Would expanding foam be OK to apply here? I have some duct seal compound as well, it looks like that may be hard to work with in there.
    Here is a photo:
    I see an extra pad, the cut lines and old mounts for a service disconnect as well. Living in a condo, I guess the unit below me
    originally had their condensing unit next to mine before relocating it to the back of the home.
    I appreciate any advice. I will call a pro if need be. Thanks!
    Massachusetts
    There appears to be a cut electrical line there, hopefully It's not live, usually I'll use hydraulic cement on large holes in a masonry foundation, and electrical insulation putty on the small ones.
    Expanding foam will work, might not look too pretty though.
    Sent from my PC36100 using Tapatalk 2
    Jul 2010
    nebraska
    I'd want to get that high voltage wiring in conduit before sealing the hole. Your electrician will take care of it,give him a call.
    Foam fill will work well. Once it expands excess can be pealed off
