    Aug 2012
    Goodman Heat Pump fan will not stop
    I have a new Goodman GPH1430 package heat pump. The problem I am having is the fan runs continually in a/c setting once the compressor starts and ends its cycle. I can push the thermostat all the way up and it will stop. I can move the setting back to where I want it and it stays off until the the thermostat warms up and starts up the compressor. The fan will start first like it should and run with the compressor but it should shut off 65 sec after the compressor stops but it does not. It will continue 24/7 unless I push the thermostat back up or turn off the system?
    I would call whoever installed it, and ask them to fix it.
    May 2008
    Missouri
    Agree with oldroc, you need to call company who put this in and have it looked at. Something is not right here. How old is system and when was the last time it was serviced?
    Aug 2012
    Quote Originally Posted by wahoo View Post
    It is brand new - Installed 5 days ago. I installed it - replaced a Frigidaire unit of the same size. Wired it to the old thermostat. Other than the fan not turning off it is working good - the compressor cycles just right.
    Quote Originally Posted by Chriss12 View Post
    I think that your installer made a mistake, then.
    We don't offer DIY advice here. If you're a Professional in the trade, then get your post count up and apply for Professional membership and we can continue this on the "other" side in private.
    If not, good luck.
    something is not installed, programmed or running correctly.
    Call installing company, or if you did it yourself as it reads in your post, reread the install manuals to help find the issue.
