Results 1 to 13 of 17
    Smile 19XL retrofit to PIC III
    I was trofitted a Carrier 19XL with R-22 from PIC I to PIC III on 1 moth ago. It is running very well up to now. Attached some photos to share with yours!
    Attached Files Attached Files
    Can
    A land down under
    Nice job Can, well done
    Wichita Ks
    looks good, did you have to change motor and bearing temp sensor?
    NE Ohio
    Nice job.I have done 6 retrofits . Threee 19xls with r-22 and 3 19xrs with 134a.I have yet to use that huge panel that comes with the relays and ISM module.I ended up gutting the low voltage side of the starter and using the space for the new components.All in all they have turned out pretty good.Everyone seems happy with it and have not had any problems.
    Jul 2012
    TX
    Good job! I have done 2 already. 1 17FA and a 19EX. Both had 4160 motors and used 134a. On the second one, we had a reduced voltage starter with big reactors on one side so we just mounted the panel on the wall next to it and ran conduit to the low voltage side of the starter. You also have to mount that auxilliary panel to translate the old style bearing sensors to switch contact on the FA. The EX was a lot easier going from PIC 1 to PIC 2.
    NE Ohio
    I agree, retrofitting from a pic 1 to pic 2 is the least complicated.On the XLs there is a small circuit board that is used to allow the PIC to control the motor cooling solenoid. This coming winter I will be retrofitting one to an EB that has been converted to 134a.I believe it still has the 32sm controls.I have also retrofitted a 30hxc from the old PSIO board to comfortlinks.
    Wichita Ks
    Quote Originally Posted by budglo View Post
    Is there a kit for the psio board to comfortlink or did you piece it together?
    Dallas ,Texas
    Quote Originally Posted by freonrick View Post
    Yes there is , but I think you could also piece one together easier once you see the parts list for the retro kit.
    NE Ohio
    There is a kit , which I got.It came with a new panel, compressor leads, transducers,flow switch ,etc.I must warn you though , there are no instructions, but it is pretty straight forward if you know both types of machines and have the most current SOM manual and wiring diagrams.
    Jul 2009
    In a mechanical room....
    Very clean, nice job can. Fyi those old controls are worth some money.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    North Florida/South Georgia
    Nice Work Can
    Hey Can, long time no see (talk)...
    How does it work on your continent with Carrier since you are an independent? Does Carrier play nice?
    Maybe some of you have had better luck but Carrier has given me so much trouble over the years I won't even consider the kit rather I go MCS.
    All my leon freaked out!
    Apr 2010
    KY,OH,IN
    I just started on one today!!
    pennsylvania
    nice looking job. Ive been involved in one so far
