Results 1 to 13 of 14
    South Eastern Missouri
    Just love the organic sound insulation addition to this mobile home furnace
    All she wanted to/could pay for was a blower cleaning. I pulled the blower and brushed off some extra from the wiring and some of the sheet metal. After I asked how old the system was she said "It came with the trailer and we bought that in 91"
    Click image for larger version.
Name:	2012-07-03 18.01.30.jpg
ID:	298531Click image for larger version.
Name:	2012-07-03 18.01.19.jpg
    After cleaning the blower I went outside to check the condenser and take a few readings when I found this:
Name:	2012-07-03 17.40.05.jpg
ID:	298551Click image for larger version.
Name:	2012-07-03 17.39.59.jpg
    Just doesn't get any better than that.
    A people who would exchange liberty for apparent safety, will deserve neither and lose both.
    Feb 2012
    Toronto Canada
    So did you make her a custom cover for her condenser?
    Run Cap Bandit was thier......Seems to be a southern merican thing
    The cover was there just not shown in the pictures.
    John Culpepper's Avatar
    John Culpepper is offline CHANGE YOUR EMAIL ADDRESS Professional Member*
    Oct 2007
    Austin Texas
    Probably isn't running too good with the suction line looking like that.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    May 2011
    Western KY
    This is why I love working on trailers... NOT! They are always caked with dirt and the people want to spend $ for a $$$ job.
    In a boiler room
    What is the transformer for in the outdoor unit?
    Not sure, didn't get into it because the customer din't want to pay for all the work that was needed. I defrosted the coil and cleaned the blower and then checked amps on the OD fan and compressor. Told her to call me when she could get the rest of the work done. She has done nothing to this system since it was new, no inspections or cleaning other than having the capacitors replaced it seems. She said she didn't even know it had a filter on it until a few months ago. I don't expect it to last the season but you never know.
    Jun 2006
    SW MO.
    You didn't leave there without cleaning the A coil did you?
    in a house, Appomattox, Va.
    I was wondering the same thing on evap coil.
    Col 3:23
    Quote Originally Posted by chaard View Post
    Yup, sure did. Well, if you consider pulling off the carpet and brushing down the bits I could brush off a cleaning then I guess I cleaned it. But it's still impacted with 20 years of crap. Quoted her a price to make her system work properly and she said "I'll call you" I said "Ok"
    The Alamo
    Quote Originally Posted by chuckcrj View Post
    Mobile homes usually have the transformer outside for the rc terminal on the t-stat and the indoor transformer for the rh terminal; no jumper between them.
    You knew that. You are just pulling our chains.
    Read, read, read!
    In a boiler room
    Quote Originally Posted by sarge View Post
    Actually I work on mobile homes all the time and have never seen a 2 transformer system. Except oil furnaces.
    They all have RH and RC jumpered and use only the one transformer.
    Jul 2002
    Centerville, Iowa
    Our Nordyne/Intertherm furnace and A/C (that I rewired way back when) had a 10 or 15 VA transformer for heat and an add-on box with a standard 40VA for cool, the thermostat was 2 wire, standard R and W, closed for heating, open for cooling, with a large DPDT rocker switch for heat/cool on the add-on box that poked through a hole cut in the furnace's front cover.
    I re-wired it for a standard 4 wire T-stat because the smaller Xfmr buzzed so loud it could be heard at both far ends of the trailer at night. As per my other thread from years ago I retained all the safeties and even added a 3 amp fuse for the Xfmr secondary.
