Results 1 to 10 of 10
Thread: opinion about Luxaire
08-06-2012, 08:13 PM #1
New Guest
- Jul 2012
- 2
i have an agreement with a contractor to install two units in my colonial style house originally we were talking about Carrier units then he told me he could save me some money with York units. I now have a new estimate for Luxaire units TCJF30S41S3A and AHE30B3X21A which are supposed to be made by Johnson Controls & York. My concern is the quality i just would like an honest opinion before i sign and commit with payment. Thanks Tom
08-06-2012, 08:29 PM #2
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
08-06-2012, 08:59 PM #3
New Guest
- Jul 2012
- 2
08-06-2012, 09:04 PM #4
- Dec 2010
- The Quad-Cities area (midwest).
- 1,749
The only problem I am concerned about with York/LuxAire is that of the micro-channel all aluminum condenser coil.
It is pretty new and untested technology.
08-06-2012, 09:56 PM #5
- Aug 2007
- 3,251
08-06-2012, 10:30 PM #6
- May 2004
- south louisiana
- 2,186
I had the HL6B heat pump
with vs air handler AVG installed
mid june of this year.
the ahu very very quiet, it is
in a closet by living room with
r/a near low on the wall.
I hardly ever hear it come on, except
late at night or early morning when
all is quiet. (no tv..no music etc)
the vs ahu handles the high humidity
here very well.
right now it is 9:21 pm outdoor temp is 84 & RH is 47%
inside it is 73 degrees and 50% RH.
as electric strip is just for emergency/back up
heat savings in winter will make the upgrade
from a/c to heat pump worthwhile.
my electric rates are lower than
other areas @ .08 per KhW.
but I didn't want high
winter heating bills from straight electric
strip heating.
to me the efficiency was second only to
comfort. with the above combination both
have been achieved. I'm really pleased so far.
the only hitch was the tstat. I finally ordered the
t-stat from Luxaire rather than the honeywell
& white rodgers stats that didn't have dehumidification
mode.
not sure if dehumidification is an issue in your location.
invest in sealing your ductwork. an average home has
30% duct loss. make sure that contractor uses only
mastic materials. duct tapes and foil tapes fail in
short lengths of time. esp if in exterme attic temps.
best of luck.The cure of the part should not be attempted without the cure of the whole. ~Plato
08-06-2012, 10:34 PM #7
If it were me ...
If the price was not to much different, I would prefer the Carrier over the York. That may be due to the fact that we get excellent service from the local Carrier Distributor as opposed to the local York Distributor.
But as mentioned here many times, the quality of the install would take precedence over the name brand of equipment.
Just my opinion.Can someone please explain to me -
Why is there never enough time to do it right the first time, but plenty of time to do it twice?
Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
Find your local HVAC-Talk Contractor: http://icemeister.net/aop_map.html
08-07-2012, 10:35 PM #8
- Aug 2008
- levittown, pa
- 58
This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
Further infractions may result in loss of posting privileges.Last edited by beenthere; 08-08-2012 at 05:46 AM.
08-08-2012, 05:46 AM #9
4dblnkldude, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
Your post has been edited.
08-08-2012, 09:03 AM #10
The HVAC contractor I use carries both. The York Affinity is nearly as expensive as the Carrier Infinity, but I'd consider Infinity far superior for comfort. Otherwise, York has a great warranty and I think hits the price points better on their lower end and midrange equipment than carrier.
On the commercail side at my work, the contractor we use prefers York due to the warranty and the supprot he gets fom his supply house. We have several installed with no issues. Althoug hthey are mostly 5 ton 3 phase light commerical units.
