Results 1 to 8 of 8
Thread: Fin tool
08-06-2012, 06:29 PM #1
Fin tool
What is every one using to straighten bent fins, what works best besides a new coil?
08-06-2012, 06:30 PM #2
Pocket screwdriver or a knife blade. Those plastic combs just break after a few runs and those metal brushes are good for nothin.
08-06-2012, 07:41 PM #3
- Jun 2012
- 114
I've had good luck with a yellow jacket finfix set, although I don't work on very large equipment, so never had too large of a coil to fix
08-06-2012, 07:47 PM #4
Professional Member*
- Jun 2009
- Owen Sound
- 22
08-06-2012, 10:59 PM #5
- Nov 2011
- Charleston, Wv.
- 692
I've used the metal one to brush across units that have been almost completely flattened.....no way you're gonna get even spacing again, so i go with the "something is better than nothing" approach. it also works well for scraping REALLY caked evaps.!!LOL!
08-06-2012, 11:56 PM #6
I do a ton of hail damage repair or just because I am waiting on a vacuum. For the most part it is carriers that seem to be a magnet for hail damage. I use supco FC1617 combs. I keep about twenty on the truck. They work good even on heavy damage if you don't get greedy. A decent sized carrier can be straightened out surprisingly well in about 15 min. Of course always always keep a pocket screwdriver for that fin that always folds and wraps over the next. Fresh combs take patience but once the teeth get a little rounded you can fly through it.
08-08-2012, 09:25 PM #7
- Mar 2006
- 186
After watching the factory guys use fin combs, it helps to use a light lubricant to make the comb slide on the aluminum easier. Just have to make sure and clean it after your done. I have used soap bubbles, diluted dish detergent, wd40 and such it helps the process tremendously.
TANSTAAFL - There ain't no such thing as a free lunch!
08-12-2012, 05:05 PM #8
I use supco supercomb. $4 @ Johnstone. Works pretty good after comb is broken in.
