Results 1 to 12 of 12
Thread: pully question
    Jan 2012
    indy
    pully question
    does anyone have a link or data sheet on how to properly remove those pullys with the 3 bolts on the front used on high rpm fans and motors? I know how to get em off but its not the right way and it never goes back on how I want it too????
    May 2012
    Upper Michigan
    Dont you use a stator puller, like atv puller? Or tap on the bolts when loose and the pulley separates, one of them two.
    Jan 2012
    indy
    you lost me with the stator-atv talk, I think it has other holes so you can tighten the bolts back into to seperate it, it just never seems right
    Apr 2012
    Paper Street Soap Company
    Those pulleys use the bolts to push the pulley off the pulley bushing.
    There should be additional holes on the bushing to do that with.
    Make sure you tighten them a little at a time rotating from bolt to bolt and use plenty of Wd-fourty.
    Also a soft mallet works to help loosen the pulley on the bushing.
    They're easier to remove than put back and re-align.
    May 2012
    Upper Michigan
    Quote Originally Posted by Six View Post
    That's what I meant. Haven't seen one in awhile and couldn't remember.
    Jan 2012
    indy
    ya its the aligning part I wondered if there was a better way
    Southeastern Pa
    Aligning is a matter of having done it a few times. I figure about 1/8 inch or so of movement onto the taper as I tighten the bolts, maybe a little less. So, it is an estimate of where to place the hub on the shaft, depending on where you want the pulley to end up when finished.
    As you can see from the attached file, the maker doesn't really address the alignment issue, only that it should be aligned.
    Quote Originally Posted by hvacmike85 View Post
    We use Pully Partners to laser align them
    Apr 2012
    A good old straight edge for alignment. Been doing it that way for years.
    As far as alignment like Time said it may take a few tries.
    If alignment was good when you started just measure the distance from hub to shaft end. If you are re-aligning or starting fresh it's usually a little trial and error. Remember keep the taper portion clean and free of any oil or dirt.
    willowick ,oh
    Those are a pain. Just takes a little patience and wd
    If the pulleys are already aligned - I take a triangular file and file a small mark on the shaft right in front of the bushing. Pull the bushing, change/replace sheave' then reassemble with.the bushing on the line and your usually in good shape.
    Was also.taught to.check alignment with a string. Pull a string from the outside edge of your sheaves/pulleys and look at how it makes contact on the inside edges of the sheave. Gaps between the string and the sheave show where and how much out of alignment it is.
