Results 14 to 18 of 18
    Oct 2001
    1" minimum between the bottom of the 1st elbow out of the pan and the top of the last elbow out of the trap into the run out line. 2" is better on larger style Trane units where the unit is pulling the air thru the coils
    "when in doubt...jump it out" http://www.youtube.com/watch?v=aMy-sAHwS4E
    May 2012
    WA
    I have always installed a riser vent prior to the trap to alleviate this problem.
    Sep 2006
    Ohio
    Quote Originally Posted by NWAIR View Post
    I think the vent needs to be after the trap, if it's before the trap, the unit will suck air through the vent.
    SE Pennsylvania
    Vent prior to trap would negate the trap. I worked with a guy years ago that said he used swing check valves, never did it myself so I have no idea if it would work.
    May 2012
    WA
    The vent needs to be before the trap. Yes, the unit will suck air though the trap during operation instead of sucking \ holding the water in the trap. The vent can be screened for sanitary concerns.
