Results 1 to 7 of 7
    Aug 2008
    levittown, pa
    Nordyne/Frigidaire blower fault
    I just installed a frigidaire 2 ton system, 14 seer heat pump with a b6vm fan coil. Upon power up it gets a signal from the stat and then the fan coil board and blower motor board start blinking red, while the green light stays on solid. In the instructions it is indicating a motor fault with no steps to properly correct the issue. There is a brown and gray harness coming off the motor that is not plugged in, but I see no female end. The blower does work for about 30 sec upon power up if there is a call then the led's blink red. Any ideas on how remedy the problem? Dip switches are set properly. Thanks in advance.
    Usually means a defecto motor. What's the full model #? Trying to see if it is a Mexican or Chinese motor? Sounds like a Broad Ocean control setup. Last Broad Ocean ECM I saw had a jumper that is disconnected for 240V. That's likely the brown & gray wires you see.
    Aug 2008
    levittown, pa
    Wow, bad right out of the box? The full model # is b6vmax24k-a. I've never had a bad variable speed blower bad out of the box, just compressors..lol. It is 240 volts at power input, is there a spot where those wires need to go?
    Sorry for buggin ya's I don't know everything but I'm not a spring chicken either.
    If I recall right, when that motor is used on a 120V furnace, those 2 wires hook into each other.
    Other than bad motor, a connection that came apart might be the only other problem. We had a furnace go down, say 2-3 years old. Took a new motor, no luck. Tried main board & ECM board, still no luck. Got in a new motor, off she ran. So DOA motor probably isn't unusual
    Aug 2008
    levittown, pa
    Well, thanks man!!!! It sucks though, but at least my customer does have ac. I have had very good luck with this nordyne equipment until now. I guess I'll just get a new motor on monday. I have to get on here more, about half the time its only when I have a problem...lol. Thanks again.
    Aug 2008
    levittown, pa
    Thanks again, I went back to recheck my dip swithches today to no avail. Tech support is telling me to replace the motor control board and the module.
    Aug 2008
    levittown, pa
    Apparently this must be a rare motor, it does not get into my hands til august 30th.
