Results 1 to 13 of 16
08-04-2012, 03:53 AM #1
- Mar 2008
- Willamette Valley, Oregon
- 62
Upgrade from Honeywell IAQ 9000 to Nest
So, subject says the gist. I'm curious if this is even a feasible upgrade, and whether or not it would even be worth it.
Has anyone seen a system go this way? I bought the IAQ largely because it was the best you could really get at the time (2008) to control my HP and AH.
Heck, I don't even know if the Nest is capable of controlling everything fully.
Anyone know?
HP and AH are both Trane.
XL15i, 4TWX5030B1 with the 4TEE3F39A1 air handler.
I would imagine an installer would need to remove the back end of the IAQ, and wire the Nest directly into the AH (since I'm pretty sure between the backend unit, and the thermostat, there are only 3 active wires).
Any advice/input?
08-04-2012, 04:32 AM #2
Priceless.
I bought a bunch of desks today, are they worth it? Last month I bought a Specialized SWorks Epic mountain bike. Worth it?
Worth what?
Let's face it, the thing is a beautiful and cool toy (both yours and mine). Clearly it's worth it, we bought them. If we get years of pleasure they will pay for themselves many times.
(You weren't planning to retire early on your energy savings, we're you? If so, and that was your only reason, it wasn't worth it.)Which makes more sense to you?
08-04-2012, 04:41 AM #3
- Mar 2008
- 62
that wasn't snarky or anything. =P
By "worth it", I guess I meant, would I lose some key function of the IAQ? I didn't mean, "Would this pay for itself". I'm a geek, it doesn't need to if it's cool enough, or has some killer feature (like, being able to access it online).
So I'd assume, given the response, you haven't done this "upgrade" yourself, or seen a case of it done. So whether the nest will handle everything the IAQ does, is unknown.
Basically, I'd imagine it must be able to talk to the external thermistor so it knows where the balance point of the HP is. And I'd assume that one could set that balance point manually. That it should be able to handle the variable speed AH fan (runs all the time at low speed, ramps up when there's heating/cooling). What about using the AC for dehumidifying? I guess I'm unsure of what functionality is controlled internally by the HP and AH, and what is controlled by the IAQ.
I guess really I'm looking for input from an HVAC tech that's actually worked with a Nest before in a HP setting, since the Nest site doesn't have a lot of the technical details (that I can find). Guess they're like Apple in that way as well.
Thanks!
08-04-2012, 05:37 AM #4
I'd get the Honeywell Prestige 2.0 instead. It does more.
08-04-2012, 06:33 AM #5
I've installed a few nests, two on heat pumps. As far as the coolness factor goes I'd give it a thumbs up, but it's not all that "smart" a thermostat when it comes to HVAC technology. It's really just a basic thermostat that has wifi capabilities and an app for your phone so it can be accessed remotely. No real user configurable settings.
08-04-2012, 08:49 AM #6
The Nest thermostat doesn't do dehumidification, or work with outdoor temperature sensors, so you would lose a couple of key capabilities of the IAQ thermostat.
Depending on where the thermostat is located, the "learning" function of the Nest thermostat will be completely useless. The occupancy sensor needs line of sight to people moving around for that feature to work.
The "cool factor" of having control of the thermostat from your phone, or computer, wears off pretty quickly. For the vast majority of people, it is completely pointless.
For me personally, the "cool factor" wore off after about a month.
The only thing I use the internet control capabilities of my Ecobee thermostat for is remote monitoring of a small home built chiller system I use for a water cooled computer system. The Ecobee thermostat has an add on sensor board that a number of remote sensors can be tied into, and sets of dry contacts that can be used to turn things on and off. It also has some configurable alert options I find useful.
The Nest thermostat has none of those capabilities.If more government is the answer, then it's a really stupid question.
08-04-2012, 12:53 PM #7
- Mar 2008
- 62
Thanks Mark! So, I'm curious, how does the Nest know when to use emergency/secondary heat if it doesn't work with an outdoor temp probe?
But heck, you answered a follow up question as well, which is "what about the Ecobee".
At this point, I'm probably going to stick with the IAQ since it does "just work". Sure, it's kinda ugly, but it gets the job done.
And the dehumidification thing, I'm sure they could add via software update (since all the system does is run the AC for a bit before ramping up the fan so the evap coils are nice and cold, then pull all that moisture out of the air with that). Seems like a software update could add that feature pretty easily.
Thanks again!
08-04-2012, 01:00 PM #8
08-04-2012, 01:12 PM #9
=p.
Maybe, but got you to give meaningful detail to your original question.
2 stages of heat, one of cooling. I believe backup would be second stage. They have a pretty thorough q/a and blog on their site. If you have better equipment, this is a very pretty turd.
Communicating equipment does A LOT MORE than just delay the fan. I'm not sure how much of those features translate down to iaq, but I suspect you are underestimating what that unit does. (oop, bt jumped in with the answer above - that's a BIG feature).
Mark, really awesome and helpful reply.Which makes more sense to you?
08-05-2012, 06:30 PM #10
Professional Member*
- Feb 2009
- Portland OR
- 1,506
I greatly dislike the Nest, the technology is not HVAC technology. Stick with the Honeywell Prestige 2.0 with redlink kit for the best control. I am constantly seeing those horrible Nest thermostats because of their flashy look the Nest would be a downgrade for you.
08-11-2012, 09:15 PM #11
- Jun 2001
- Oklahoma City
- 2,587
Agree with others. other than WiFi and being pretty it's a basic big box store grade thermostat. No advanced features that most other stats in it's price class have.
08-12-2012, 10:15 AM #12
They should being keeping the nest on the shelf next to Lux and Hunter thermostats.
All 3 are pieces of junk."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
08-12-2012, 10:27 AM #13
- Jun 2001
- Oklahoma City
- 2,587
