Results 1 to 4 of 4
Thread: Zoning question / issue
08-03-2012, 05:48 PM #1
New Guest
- Aug 2012
- 2
Recently had a Trane heat pump / air handler installed to replace an old York system.
Question is this, I have a 2 zone system (upstairs and downstairs) via a single HVAC unit.
If I set upstairs / downstairs zones to say 74 degrees, the system runs all day and can not keep either zone of the house less than 74 degrees.
If I just run the downstairs zone, I get poor airflow through downstairs vents, and again, unit runs continously and cannot cool the house...
If I just run the upstairs zone, I get good airflow through the upstairs vents, and can actually keep both the entire house comfortable
Any ideas as to what the issue may be...I had the same issue before the install, so I do not suspect that has anything to do with it...seems like there is a issue with airflow / cooling to the downstairs zone...
08-03-2012, 05:53 PM #2
There could be a number of issues involved but it's curious that having only the 2nd floor calling would keep the entire house cool. Along that vein, I'd suspect a zone damper position issue (could be a switch in the wrong position) or it could be a wiring issue. Not knowing what the zone equipment is does make it more difficult to offer any insight but generically they all do pretty much the same thing so I'd definitely need to verify zone damper positions as a first step.
08-03-2012, 05:54 PM #3
Yup, sounds like a closed downstairs damper.
08-04-2012, 12:49 AM #4
Is there an electronic bypass damper?
