Results 1 to 13 of 14
Thread: v belts
    Aug 2012
    v belts
    Large air handler belts keep turning over on pully sheives? The more or less tension I put on them does not matter. Please offer suggor pro advice.
    Jul 2012
    Belt is probably loose side to side, and miss aligned. Correct the alignment first. The miss-alignment is waring the sides of the belt - making it too narrow. Depending how long its been that way, the sheaves / pulleys are probably worn as well, and may have to be replaced. OR you are running the wrong belt.
    Quote Originally Posted by Blows_Sucks_Heats_Cools View Post
    sage advice
    Aug 2012
    Thank you blows sucks heats cool! Just need advice.
    Dec 2011
    ms
    change bearings
    up in the hizzy
    get rid of adjustable and use banded belts with new sheaves, they work great with shock loads.
    May 2012
    WA
    Check your alignment.
    Oct 2011
    Chicagoland Area
    Too much belt is riding outside of the sheave will cause this. You may need to open the pulley or change to a larger diameter.
    Mar 2011
    Long Beach, CA
    Use a straight edge or string for alignment.
    _______________
    Understand the symptoms and you will find a solution.
    Oct 2010
    Austin, TX
    Put the right sized V-belt on it
    What belts are you using and whats the sheave model number.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    NH
    Sheave or pulley is really worn or you have the wrong type of belt... Like a A belt when you should have a B belt.
    N.W.Indiana
    Check wear on sheaves. Replace if worn. Alignment is critical on many units. After 25 years of using a straight edge or string, I have been using a laser sheave alignment tool and it is so easy and accurate.
    Apr 2010
    NYC
