Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 40
  1. #27
    burlington county n.j.
    Quote Originally Posted by mcewans View Post
    I think you can solve this problem by hooking up the C terminal to the common on the 24V. When power is lost, the compreesor is "locked out" and won't start up until the lockout delay in the thermostat is satified.
    any safety or connection after the thermostat could still cause the contactor to chatter, i would still install a time delay at the contactor.
  2. #28
    Jul 2000
    NW IL.
    The new scrolls have a thermal relief valve. Once open it does the same thing as a pressure relief allows thermal overload to heat up and shutdown. The overload maybe resetting before the thermal relief closes. Showing no pumping action. Watering down the compressor reset both safeties. Make sure everything is clean. CFM is correct. And heard overcharging will cause the thermal to open as well.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
  3. #29
    Houston,Tx.
    Quote Originally Posted by GrumpyPawPaw View Post
    If bad valves, it wouldn't have returned to normal pressures.
    Scrolls don't have any valves,at least not like the old recrips did.
  4. #30
    Jul 2000
    NW IL.
    The Copeland Scrolls will have a decal stating that it has a thermal device.
  5. #31
    Southeastern Pa
    The decal is applied to units that have a mechanism that disengages the scrolls from the motor, allowing it to run without moving the scrolls.
    http://www.emersonclimate.com/en-us/...rotection.aspx
    2 Tim 3:16-17
    AOP Forum Rules:
  6. #32
    Quote Originally Posted by timebuilder View Post
    The scroll mechanism still turns, the ASTP just bypasses the discharge gas internally, which is why no refrigerant is moving through the system when the ASTP is active.
    The bypassed discharge gas trips the thermal overload in the motor windings.
    http://www.emersonclimate.com/Docume...p_overview.pdf
    The compressors listed in the link you posted are commercial AC and refrigeration compressors.
    The K5 scroll compressors used in residential equipment for the past couple of years have a similar feature. I works the same, but has slightly different implementation inside the compressor.
    The previous K3 compressor don't have the ASTP feature.
    I haven't noticed the ASTP warning sticker on a residential unit with a K5 scroll compressor yet.
  7. #33
    Southeastern Pa
    First I'd seen that internal closeup. Nice.
    2 Tim 3:16-17
    AOP Forum Rules:
  8. #34
    Quote Originally Posted by michigan1 View Post
    Its single phase. You mean its running backwards on overload?
    Single phase Scrolls can run backwards if their check valve leaks through, and they have a short power outage and then come right back on.
  9. #35
    Houston,Tx.
    Yes they will, if you have not personally witnessed this like I have, some might find it hard to believe.
  10. #36
    Massachusetts
    Is it a heat pump? Not familiar with the model number but if it's a HP, that's a classic reversing valve problem. Little difference or none between high side and low side and a loud compressor!
  11. #37
    Apr 2004
    Des Plaines,IL
    That is not what I have seen in the field.
    Of course, the least expensive installer bid for a commercial job means that a C wire is rarely provided, so in that situation, the point is moot.
    I checked, and this works with the FocusPro Series. I am not sure about the VisionPro Series.
    Stuart
    Lack of airflow destroys compressors.
  12. #38
    Jul 2012
    Phoenix, AZ
    You should try and pump down the unit. If the unit doesn't pump down in seconds then its a bad valve.
  13. #39
    Jun 2007
    NE PHILY
    Can this happen if this unit short cycled , example customer playing w/ non digital stat?
