Results 14 to 26 of 30
    Jul 2009
    South Carolina
    Sad to say but it looks like microchannel is the way of the future.
    Its cheaper & uses less gas which means its cheaper for the manufacturers.
    They'll let us deal with all the problems till they get them right. They can probably make 3 of them cheaper than one copper tube & fin coil so they still come out cheaper if they have to warranty them every couple of years. They can justify going to aluminum indoor coils because of all the copper coil leaks
    indoor but there has never been a problem with outdoor copper coils leaking.
    There is no justification to move to aluminum microchannel except shear cost cutting.
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
    Oct 2010
    The advantage of aluminum, to my marine customers, is less corrosion. On copper/alum coils, within a couple of years the heat transfer between the alum fins and the copper tubes greatly decreases, due to corrosion between the dissimilar metals. We are constantly battling this with coil treatments/dipping to slow the corrosion. Condensing units last about 5 years.
    You can get copper/copper coils, but are $$$$!
    May 2005
    Lubbock Texas
    Quote Originally Posted by garyed View Post
    I was at Trane's factory in Clarksville last week. I watched them make a microchannel coil. They will be the norm in the next 5 years.
    The premise of ventilation is that the OA is clean or of sufficient quality to be used for dilution. Traditional ventilation is somewhat being threatened by the fact that the EPA is changing the requirements for outdoor air quality which is creating non-attainment zones in what is now becoming a significant portion of the country. That means that buildings in those areas will need to clean up the OA before they bring it into the building.
    www.genesisair.com
    Genesis Air Inc.
    Oct 2010
    Maye if everyone is getting into it, they will put their heads together and work all the bugs out.
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by tharding54 View Post
    Good point about marine applications, tharding. I also wonder how they will hold up at paper mills and other industrial sites with a chemical environment. If you're seeing improvement in marine environments, then I'm cautiously optimistic.
    Oct 2010
    Ability to withstand vibration is another concern. The spine fin condenser coils, for example, vibration will cause the coil of alum tubes to settle 6 to 8 inches, and the bottom tube will rub a hole it it.
    NW AR
    As has been said, get used to it. Your brand will be going the same route eventually. I hear many of you saying its just on the cheap builder models. Not true. Some brands are using them on their high end, high seer equipment as well.
    They still havnt figured out how to get them to drain properly in defrost with heat pump systems so I guess those that are so against them can purchase heat pumps and wire them to run straight ac...
    Jul 2009
    South Carolina
    I much prefer Goodman's small 5 millimeter copper tubing than aluminum microchannel. I'm at the beach & we have copper tubing with aluminum fins doing just fine for years. The big problem of course is the corrosion causing poor heat transfer as the units get older but its never been a problem causing leaks in the coils like microchannels are having. I also wonder what would happen if any trash got into a microchannel coil.
    Gary
    Jul 2012
    Southwest
    I repaired one Trane 5 ton split with the alum solder kit, and replaced a 20 ton condenser coil on a brand new Carrier split. (it blew out in several places and was hopeless to fix, after one attempt failed)
    Ordering a new coil for a 5 ton+ system could be months out. Your customer could be in trouble in the middle of Summer.
    Even the salesman will admit all the larger micro channel coils fail. Good luck repairing anything other than a pinhole.
    Oct 2010
    Yeah, I'm concerned about cracks due to boat vibration.
    Virginia
    Make sure you add or at least offer a 10 yr part and labor warranty on the micro channel units
    Jul 2012
    Western KY
    Not a fan myself. 2 big issues, as stated, leaks and charge. You worried about trash in them. Well most have POE oil so better keep them shinny clean. As small as the passages are will not take much to junk them. That being said they will probably have to be replaced for leaks long before the ever get that dirty. Seeing them in refrigeration too.
    NW AR
    Charging is as simple as any other unit. Have had no leaks so far so cant attest to that part(other than a dry charge new in box that had been hit with something). As far as trash, the passages are bigger than the passages in a screen before an orifice, for example. Dont get trash in them. Simple.
    I wish they would stick with copper too but looks like they arent going to...
