    Dec 2010
    new jersey
    No split, but heat rec coil....
    I found a leak today on a condenser discharge header.
    My problem is I have never had to repair one before and was hoping someone could explain the best way to do this.
    4 compressors on an old Hill rack, only one condenser and piped w/ no split.
    The rack does have a hr coil, my question...can I, while monitoring HP, shut down the discharge bv and run the condenser out of liquid, w/ the fans off, then shut rack off, and close drop leg bv?
    Then dump the remaining gas in a pre- pumped down circuit.
    Does this sound right? Or is there a better way.
    Oh yea, There are two other racks w / same R-22 and could dump it in the suction header.
    Quote Originally Posted by sprmktrefertech View Post
    That isn't going to work.
    I shut the fans down, run the head pressure up to ALMOSt trip point, then shut both BV off and run the recovery machine.
    Dec 2010
    new jersey
    Thanks, Jp!
    Nov 2003
    Another tip. Use the recovery machine to pump into the suction header instead of tanks.
    Jul 2000
    Cuenca EC
    Quote Originally Posted by smilies View Post
    I like your thinking. That will speed it up a lot.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
