Results 14 to 26 of 46
    Oct 2011
    La.
    40 lbs is not that much. your oil is in your cooler and should return in time with the correct charge and load. look for your leak again and again with several leak detectors.
    good luck
    Oct 2011
    South Georgia
    Check your compressor motor terminals area for an orange oily stain. The motor terminal pins have o'rings that will swell and contract with temperature changes. Leak test with motor cooled down to ambient or lower.
    May 2002
    Tube leak is doubtful but NOT impossible.
    Schedule an eddy current ....
    Leak check and check and check every inch ...
    Still can't find it ?
    Go back in two weeks and another two weeks and follow the factory charging procedure ,I'm sure you did this time , and if it's low you have an idea of your leak rate.
    mikeacman
    East of big city prices.
    Quote Originally Posted by Freightshaker View Post
    Also to add ...
    I would start with the condenser. Unless you have reason to believe the evaporator got a little too cold.
    I guess it's possible but what kind of power washer could they have used???
    Jun 2012
    I don't know, what does the book say?
    You would have to ask your buddy about that. I'm sure he could come up with some book from 1968 that says its ok to use a power washer. Who knows.
    Jun 2012
    Aww still caught up in the moment
    May 2002
    I doubt a pressure washer would cause leaks ...destroy a coil yes
    Im a fan of low pressure high water volume washing , by low I guess I mean balanced ,enough pressure to do the job but not enough to strip paint ...
    That's just crazy
    mikeacman
    May 2002
    Back on topic....
    To the OP...
    Make sure you leak check all your solenoids...found those leaking before and they don't always spew oil when they leak...unless it's the oil solenoid
    mikeacman
    The Hot South
    Smile
    Quote Originally Posted by Dallas Duster View Post
    Now thats funny.....I don't care what anybody says....
    Wichita Ks
    how did you decide it was only 1/2 gal low on oil?
    Most leaks I have found was at fittings on top of oil separator.
    Apr 2009
    Ok I am going to soap the whole outside with , well soap And go from there .
    Apr 2009
    Off on oil level now its goning off on low saturated suction temp or refrigerant flow
