Results 1 to 9 of 9
    Jul 2012
    ytk6d5f2 need help
    to manually turn on purge pump set for 30 per hr but hasnt run
    Quote Originally Posted by ckcraven View Post
    hasn't purged or hasn't run? is the chiller running?
    Jul 2012
    hasnt purged, chiller is running
    Jan 2011
    Please describe the problem.
    You cannot "turn on" a York purge. Setting the "number" to 30 is a setting to show an alarm if the purge count reaches 30 in one hour (after the first hour of chiller runtime). A York turboguard purge works only when the chiller is running.
    Is this a single line panel?
    perhaps there isn't any air in the chiller to be removed...that would be a good thing.
    Dec 2008
    Dixiana, AL
    need help, someone that knows
    Jul 2012
    that would be good if there is no air, but man that thing can really do some surging at times
    Aug 2009
    Prattville, Alabama
    Air is not the only thing that can cause surging.
    Tijuana, Mexico
    The purge pump has to be working when the chiller is in operation, when you start it check the purge pressure max. 90 psia. and then purges.
