Results 1 to 10 of 10
Thread: 30RB080 air cooled chiller
07-31-2012, 02:09 PM #1
New Guest
- Jul 2010
- Malaysia
- 1
Hey Guys,
i am using the 30RB080 air cooled chiller.....How do you guys run the fan motor in full speed? i have totally modified my chiller into DOL start and stop system and i am stuck in testing the fan motor....It seems it need a PCB board to give contact it to run at full speed? Anyone has overcome this issue....Please get back to me ASAP as i am urgently requiring some answers
thanks
07-31-2012, 04:16 PM #2
made this its own thread, and moved it to the open chiller forum.
07-31-2012, 09:18 PM #3
- May 2002
- evansville indiana
- 892
Not sure what you mean by "DOL"...please spell it out
The fan motor...is it connected to a motor master 5 or in other terms a small variable frequency drive?
Does this have comfort link controls ?
If the fan is connected to a vfd or MM5 the controls supply an output to ramp the fan(s) up or down ... In test mode these fans won't necessarily run at full speed.
I wish I could help but need more info...mikeacman
08-01-2012, 08:41 PM #4
Professional Member*
- Aug 2002
- Greenville SC
- 398
The fan motors are controlled by the Fan Board. You shouldn't need any extra boards to make them run. If you are trying to test the fans operation in the test mode, and you have a VFD, then there are two imputs in the test mode. Pick the fan you want to test then turn in on. Then scroll down to the first setting below the fans, and imput your fan speed for the VFD. I'm not sure what you mean by DOL either.
08-01-2012, 09:27 PM #5
- Jul 2007
- The Hot South
- 927
Please tell us what you mean by DOL.
08-01-2012, 09:37 PM #6
- Sep 2008
- A land down under
- 285
08-01-2012, 09:40 PM #7
- Jul 2007
- The Hot South
- 927
08-01-2012, 11:00 PM #8
- Jul 2012
- TX
- 51
You should be able to go into test and use the VAR_A command to ramp the fan up.
08-04-2012, 03:13 AM #9
- Sep 2008
- A land down under
- 285
08-04-2012, 04:58 PM #10
- Mar 2011
- North Carolina Piedmont Area
- 309
