Results 1 to 8 of 8
Thread: condensor cover debris cap
08-28-2006, 09:55 AM #1
- Jul 2006
- florida
- 10
I see ome people have a cap/cover on their heat pump over the fan (top). When the unit kicks on it opens up and then shuts to keep water debris out when the unit is not running, right? Anyone have any thoughts on this and where do you buy them. thanks
Scott
08-28-2006, 02:08 PM #2
- Aug 2006
- High Point, NC
- 155
Do not like anything covering unit. This type of device will cause the motor to work harder to open. Also, if it fails to open you can burn up your unit. The motor is not designed to overcome increased static pressure of this type of item.
08-28-2006, 07:30 PM #3
I have never seen these and who would design something so stupid but I think you must have seen it on you might be a redneck
Knowledge comes with experience
08-28-2006, 08:04 PM #4
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,212
http://www.koolkap.com/webapp/GetPage?pid=17
they've been around awhile
08-28-2006, 08:06 PM #5
That is really different I've never seen any in my area
09-11-2006, 09:41 AM #6
- Jul 2006
- florida
- 10
thank you dandyme
09-11-2006, 06:18 PM #7
- Dec 2003
- 709
Waste of money in my opinion. Condensors are designed to be left open outside. Not hard to clean the leaves out of the bottom, especially when it has to be clean annually anyway. And rainwater definitely doesnt hurt anything.
09-11-2006, 06:59 PM #8
There are heatpumps out there where that cover is factory installed, so while I never liked the idea, the covering of the fan opening on off cycle might be beneficial in certain areas where it's extremely dirty. JMO.
