Results 1 to 13 of 38
    Nov 2007
    Mississippi
    copeland discus oil pressure
    What should the oil differential pressure be on a copeland discus compressor? I just replaced one today (grounded) and the new compressor will unload when still having a call for y2. Starts loaded with no voltage to unloader and after running about five minutes, cylinder unloads. I am thinking it has something to do with the oil pressure but do not know what the range is. This is a 15 ton split york. Oil burnt so I installed suction shell. Going back tomarrow to replace oil, suction filter, and liquid line drier again. Also the suction screen on the inlet of bad compressor was completly plugged. Currently I have 35 delta P oil (loaded and unloaded). Any suggestions?
    what controls the electric unloader?
    i would guess a call for y2 would deenergize the electric unloader?
    does it just load and unload on suction pressure?
    does it load on discharge air or chilled water temp?
    it is a york so i guess it is a pump out system not a pump down?
    true knowledge exists in knowing that you know nothing.
    Nov 2007
    Mississippi
    Two stage thermostat. Y2 deenergizes soleniod 24v. It does not pump down.
    Quote Originally Posted by socotech View Post
    If it has an electric unloader on, then it cannot unload or load by itself. If the solenoid coil is de-energized, then it should unload.
    Did you install a new unloader with a new compressor ???? Or you used the old one ?
    Nov 2007
    Mississippi
    New unloader. Old one was leaking.
    Las Vegas NV
    Is it a single head compressor, 3D model?
    Nov 2007
    Mississippi
    No voltage before and after unloading
    Nov 2007
    Mississippi
    Quote Originally Posted by powell View Post
    It is a one head compressor
    Las Vegas NV
    Ah, it uses the "Moduload" type unloader. It unloads based on compression ratio. It will be easier for you to understand if you read the AE bulletin from Copeland.
    Here's the link
    http://www.hvacrinfo.com/ae_index.htm
    Bulletin 21-1278
    35 PSID is low for a typical copeland.
    I look for 50 net oil on a new and I've seen it as high as 55-57 on a new pump.
    I would immediately be looking for issues with a 35# net oil pressure.
    Is the oil level adequate? Is the system very dirty?
    Apr 2012
    Paper Street Soap Company
    Im almost positive loaded is de-energized.
    Y2 doesn't connect straight to the unloader.
    That said letting a thermostat load and unload a compressor is a bad idea.
    Run that thing unloaded long enough and you'll be replacing it.
    Does it have a Sentronic oil pressure unit ? Ive got two antique 30 ton york splits with new Copelands in them. Their not staged by the T-stats anymore.
    Remember to use crankcase pressure to check oil pressure, not suction.
    Nov 2007
    Mississippi
    Here's the link
    Bulletin 21-1278
    Thanks for the link. I needed that.
    Nov 2007
    Mississippi
    Oil level maybe a little high. Its about 3/4 sightglass. Yes system is dirty.
