Results 1 to 11 of 11
08-16-2012, 09:20 PM #1
Need a good wireless stat for a commercial application
I need to find a good wireless t-stat to control two stages of cooling and two stages of heat for a carrier RTU. It is located on the roof of a bank. There is a short in the wiring and pulling a new one would be a ton of work. Thanks in advance.
Sent from my iPad using Tapatalk HDTo the man who always did it right. I love you dad and I will miss you to much for words.
Stay Thirsty My Friends
Support the Skilled Trades Don't DIY
08-17-2012, 09:47 PM #2
I guess no one has an answer?
Sent from my iPhone 4s
using TapatalkTo the man who always did it right. I love you dad and I will miss you to much for words.
08-17-2012, 10:09 PM #3
Honeywell? They should have a multi stage wireless stat.
08-17-2012, 10:53 PM #4
Here ya go.
http://jacksonsystems.com/view_product/26409Make your expertise uniquely valuable.
08-18-2012, 08:26 AM #5To the man who always did it right. I love you dad and I will miss you to much for words.
08-18-2012, 11:08 AM #6
Its works well as long as the control module is not mounted in a metal enclosure.
08-18-2012, 11:37 AM #7
Great. I can mount it in the mechanical room on the mezzanine that is above the teller line. This should work perfect.
08-19-2012, 10:15 PM #8
The Honeywell Focus Pro 5000 (non programmable) and 6000 (programmable) wireless stats will do 2 stage operation. We have used these in many residential and commercial applications with 0 failures.
Also, if any 2 of your wires are still useable, you can use the Honeywell Prestige IAQ 2.0, which only needs two wires to power the stat, and otherwise is wireless to the control module. The Prestige 2.0 gives you many more options, including the addition of wireless remote sensors if needed. And yes the 2.0 can be resi of commrecial use, you just have to choose which in the set up menu.Hi, my name is Glenn, and I'm a Toolaholic!
08-20-2012, 06:14 PM #9
08-21-2012, 10:04 PM #10
08-21-2012, 11:35 PM #11
- Jul 2012
- Southwest
- 114
I have installed 20+ Honeywell 6000's with 0 failures.
