Results 1 to 8 of 8
Thread: Tall service.
    Dec 2006
    Litchfield,Il
    Tall service.
    I love these calls . I know I have to go up there and possibly clean that coil. This Lennox was hung up in an alley. Ended up being just a routine clean & check. Attachment 279811
    If your not getting the results you desire then change. People change from either desperation or inspiration.
    Tallahassee, FL
    At least it should stay pretty clean up there. Sure makes a compressor job 20times harder.
    north suburbs of Chicago
    Hope that pad stands up to UV light a long,long time
    Cincinnati, Oh
    Quote Originally Posted by Glennhvac View Post
    I was thinking the same thing.
    "Just get it done son."
    Dad adjusted
    Dec 2006
    Litchfield,Il
    I would think bringing it back down to ground level to do a comp. change out would be in order.
    Jun 2012
    The lineset and furnace vents go underground!?
    Cincinnati, Oh
    Quote Originally Posted by pas1216 View Post
    not too uncommon.
    I actually just did a lineset like that, where a concrete slab was 3' higher than the subfloor. Couldn't get up the exterior wall.
    Never seen the dryer vent pariscope before either I take it?
    Dad adjusted
    Mar 2009
    Mid-Mo
    There's nothing "routine" about doing a clean and check on that thing. What a PITA.
