Results 1 to 13 of 14
    Jul 2012
    Phoenix, AZ
    Post Oxy acetylene help need some tips?
    I never used oxy acetylene before I'm unsure on what my pressures should be when I hook up my regulators for oxy and acetylene. What pressures should my oxy and acetylene be at? Any thoughts?
    Feb 2011
    Cloverdale,Ca
    Depends upon your tip size and what task you are performing. You should consult your manufacturers literature to find the correct pressures.
    Living the dream !!
    Southeastern Pa
    Your cut set literature will have the basic pressures you need.
    2 Tim 3:16-17
    AOP Forum Rules:
    Jul 2012
    Phoenix, AZ
    Nice thanks guys.
    Read the manual.
    I find that most guys run pressures way too high.
    Assuming (big leap) that you're using the typical small oxygen acetylene setup, 5 and 5 are good starting points.
    Apr 2012
    Paper Street Soap Company
    Acetylen 5 and Oxy 15.
    Been setting them up that way for years.
    May 2012
    Upper Michigan
    Does he know how many turns to open acetylene tank?
    Nov 2011
    St. Louis
    7 A, 11 O and adjust from there at the torch valves. Nice strong hiss, 3/4" blue flame for suction line, 1/2 for liquid line.
    Keep the service wrench on the acetylene tank and poised to close in a hurry.
    Works for me - however I have no idea what my tip size is...just the one I inherited and got used to.
    I'm betting once you get used to it...you won't be paying all that much attention to pressures. Until your tanks run out.
    May 2012
    Upper Michigan
    [QUOTE=Keep the service wrench on the acetylene tank and poised to close in a hurry.
    [/QUOTE]
    Also a great tip,
    open tank quarter turn past when you see the primary pressure gauge read pressure.
    Chicago
    Check out this guy on YouTube. He has a lot of great videos on brazing that are made well.
    http://www.youtube.com/watch?v=hZlcS...e_gdata_player
    The Day You Stop Learning Is The Day You Think You Know Everything.
    Jul 2012
    Phoenix, AZ
    Awesome thats sounds easy enough to remember thanks.
    Jul 2012
    Phoenix, AZ
    Thanks I appreciate it.
    Dec 2010
    Somewhere in Cali
    I would say 5a 7o.
