    affordable absorption chillers?
    i am looking for a small absorption chiller or something like them that can cool a house with heat coming from a wood pellet boiler system. i thought about having the contractor install a compressor chiller but i want a low energy chiller that runs on heat.
    Fort Worth, TX
    Short answer: even if you could find one, avoid residential absorption HVAC like the plague.
    Long answer: same as above.
    "In this house we obey the laws of thermodynamics!"
    - Homer Simpson
    Keokuk, IA
    The only place you'll find absorption chillers anymore is at power plants where they have a lot of waste low pressure steam and large cooling demands over 500tons.
    I wonder if they make a absorption chiller that will run <20psi that you'll get from a residential or commercial boiler. When I say "low pressure" above, I mean <150psi.
    Bottom line, unless you have minimal electricity because you in a off grid home running on solar panels, I don't see this being very cost effective compares to more conventional technologies like a geothermal WSHP.
    Aug 2009
    Jurupa Valley, CA
    And if this IS for off-grid use, you might want to look into making electricity from that heat, charging batteries, and looking into a 48V mini split.
    Keokuk, IA
    I'd say avoid mini steam turbines like the plague as well.
    Better to get a small scale solar and wind installation, then insulate the crap out of the house so you don't need much cooling capacity to begine with.
