    I am getting a Trane XR13 heat pump installed soon and before tech comes out to look, he tells me I will need a Trane thermostat. I told hime I have a Honeywell TH622D which states it hooks up to about any system, Anyway. do any of you folks know if this Honeywell will work with a XR13?, or will I have to spend $$$ for a new Trane Therm?
    http://customer.honeywell.com/Techli...0s/69-1785.pdf
    [Edited by rac43 on 08-25-2006 at 03:26 PM]
    L.I.Newyork
    You went with trane dont be cheap now.Thats what there all about.Smoked motor have to buy it from trane.Controls have to buy from trane.This system uses this tstat have to buy from trane.Get it yet.Youll probally need that stat he suggest.Get it yet?
    On the other hand...
    that's a Focus Pro not a home store cheapie. Should do just fine with a single stage heat pump with backup electric heat. So unless you are going dual fuel, this stat is all you need. It's like the Trane XL600 stat so if you bought a Trane stat, you could well end up with the same stat
    Smile
    Thanks loonie, that helps me a lot!
    he should give you a stat dang you just bought a hole system from him.
