+ Reply to Thread
Results 1 to 9 of 9
Thread: Liq. Level set point on a centrifical ?
    Jun 2010
    colorado
    What is the purpose of this setup . How does the machine react as it maintains set point and with different condenser loads ? For example , if you had 3/4 of the barrel full of liquid I would probably expect a higher condenser pressure verses if it was 1/4 full of liquid . Am I even in the ball park with analogy ?
    Dec 2010
    On a Peninsula in NE NC
    Never seen a liquid level s/p on a cetrifugal
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Apr 2006
    mechanical room
    It's on a York ykcf machine . I think it is a variable orifice in the liquid line between the barrels controlled by a actuator. But Im hoping someone else can shine some light on his subject .
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by newbe0507 View Post
    Liquid level keeps the subcooler covered to gain efficiency. As long as you don't start covering condenser tubes with liquid, the level in a condenser barrel doesn't change the pressure in the barrel any more than the amount of liquid in a drum of refrigerant changes the pressure in the drum.
    Jun 2010
    colorado
    What is a good set point and why ?
    Dec 2008
    Dixiana, AL
    Actual number for a setpoint depends on whether or not the guy that commissioned the chiller knows his butt from 3rd base. % can vary depending on calibration. The goal is to just keep the subcooler covered. You can calibrate the controller (which I won't get into here) and you should be able to set at 40% +/- and do well.
    Jun 2010
    colorado
    thanks Klove
    also see them on turbocore machines
    Klove, thanks a lot for your explanation of this. I've wondered about it myself, and I thought it might have had something to do with not starving the evaporator when you're running cold condenser water. I wish I got more inspection and wrench time with the YKs and YTs, but I only get to play with the beige machines.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
