Results 1 to 8 of 8
    Jul 2012
    Baton Rouge Louisiana
    Feildpiece Srh2 Psychrometer
    I just got my Feildpiece Srh2 Psychrometer to figure my super
    Heat a little easier. Who uses, or used to use one and what do you think?
    Mar 2012
    West Chester, PA
    I use an SRH3 but usually only for accurate in duct db/wb haven't used it to figure target superheat. Usually try to use a charging chart if available.
    Jul 2012
    I have been taught that my TEET should be 20 degrees In the attic in the return and the supply plenum. When I use my srh2 TEET might only be 16-17 degrees. When you take your Wet bulb do you do it at the return down stairs or in the return in the attic? I know because of how hot some of these attics are in Louisiana I might gain a degree or two in the heat of the day from downstairs to in the attic.
    Mar 2012
    West Chester, PA
    It should be taken in the return at the unit. The temp of the air in the space is not always the same as the unit. The performance of the unit should be judged based on the air it is conditioning not the air in the space. (although ideally they are the same) if you take both readings you can identify duct work issues
    Mar 2012
    West Chester, PA
    20 delta t will only be on days where there is very little humidity in the space. Once you start removing humidity, you are removing latent heat which will not be reflected in a dry bulb delta T
    Jul 2012
    Cool. I've been wondering about that. Prior to getting the srh2 I never took a wet bulb. Now on a fixed orifice system I KNOW it's fine tuned..... Not just guessing what the superheated should be if there is no chart on the unit.
    Jul 2012
    Superheat. Not superheated!!! Darn auto correct on my phone
    Jan 2011
    Boston, MA
    I use the shr2 almost everyday for figuring SH and just for taking wb and db readings. I love that thing and have never had an issue in the 2 years I've had it.
