Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 70
  1. #27
    Central NJ Area
    Quote Originally Posted by fordrules View Post
    Fluke 902, 87, T5-1000, and 52II. I use the 902 for most electrical troubleshooting.
    The 902 is not good for resistance readings in my opinionn and I would not use it for anything except to check for open or closed circuits.
  2. #28
    I retired my Fluke 337 and 116 to backup duty, and got a Fieldpiece SC56 for my tool bag to save weight and space.
    For temperatures I use a Fluke 52II, and a variety of Fluke probes.
    I'm not aware of any electrical test meters that have a temperature function that is worth using.
    You need a dedicated temperature measuring instrument, that has good compensation for the temperature of the meter, and has filtering against interference from stray signals/voltages.
  3. #29
    Oct 2002
    Plano, TX
    I use a Supco. More scales and features then my fluke. Larger LCDs. I bought 4 because they were so cheap and they have lasted for years.
    Fluke assessories are very overpriced.
  4. #30
    Quote Originally Posted by timjimbob View Post
    Supco has no filtering against interference from stray signals/voltages, and questionable compensation for the temperature of the meter.
    And yet are worth every penny.
  5. #31
    Oct 2002
    Plano, TX
    Supco issues are insignificant at 120 volt circuits, but you may be right when checking flame sense circuit.
  6. #32
    May 2012
    Grand Junction, CO
    Fieldpiece HS36. Had it 4 years now with no issues.
  7. #33
    Jan 2011
    Portland, OR
    I use Fieldpiece LT17A. The hanging magnet comes in handy. Comes with amp clamp to attach to the leads so you can take motor readings with the door on.
  8. #34
    I thought you were talking about their thermocouple thermometer, I wasn't even aware they made a multimeter.
    Scary though, trusting my life to an electronic device made by Supco.
    No thanks.
  9. #35
    Apr 2012
    Paper Street Soap Company
    I have a fluke 52 II also..
    That things been through hell and high water still works though
    I actually liked my old Fluke 52 better.
    You could calibrate it.
  10. #36
    Quote Originally Posted by Six View Post
    You can calibrate the 52II using the offset function.
  11. #37
    Jul 2009
    South Carolina
    I just keep a cheap Sears multimeter with me on the job.
    http://www.sears.com/craftsman-multi...p-03482139000P
    It does everything except amps so I have a separate Amp meter.
    This thing does volts,ohms,capacitance & temperature if you have a K-type temp probe for less than thirty bucks. I've got about three or four of them in different tool bags. The temperature part seems to only last about a year but its a handy little tool & if I break it, leave it in an attic or under a house I just buy another one. I learned along time ago not to buy expensive tools if a cheaper one will do the job in the field. Expensive tools are for the guys that are neat & take care of them. That ain't me. I'd go broke if I replaced all the tools I break or lose with top quality ones. To each his own but if you're looking for something cheap that will do the job this one is hard to beat.
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
  12. #38
    Quote Originally Posted by garyed View Post
    Short of accidentally dropping a tool into a place where it is not retrievable, actually losing a tool is a foreign concept to me.
  13. #39
    Jul 2009
    South Carolina
    I'll bet you're very well organized. I'm just the opposite. I lose things constantly. I have a bad habit of laying tools on the ground that I just can't break. I lose tools in my own truck. I just found one of my amp meters in my truck that I thought I lost a month ago. I've left everything from a 7 gallon wet vac to an H-10 on the job site & not realized it for days. Stepping on my gauges or meters is a common occurrence. The guys I work with are always making fun of me for either losing or breaking things. So for me, cheap is the way to go.
    Gary
