    Couple more relic what is its?
    Frosty on the right next to the POS Payne. Froze stiff, no air coming out the top like a fan blade going backwards. Check out the coil.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	279221   Click image for larger version.
    This neighborhood of 4 plexes built in the 60s originally had 2 brands. Bryant TTW condensers sitting on the ground and this one, also a TTW sitting on the ground. A few of each are left. Found this one still running. Know what it is? It will be a challenge!
    Feb 2007
    S.E. Missouri
    Well, the cabinet looks like a Heat Controller/Addison in the first picture. I know a couple 1974 Heat Controllers around here have a Modine corrugated all aluminum coil. The second picture, Heatwave International or Afco?
    burlington county n.j.
    2nd one looks like a Fedders model i have seen installed thru wall in a condo complex
