Results 1 to 13 of 27
    Jul 2012
    Everett, WA
    Confused Cornelius ABS leaking coke out of ice drain tubes
    I had a call from one of the 16 stores that the company I work for takes care of, they say that there was coke syrup coming out of the drain tube for the ice storage bin. They disconnected the coke so that they wouldn't lose all there coke syrup.
    I get there and have them hook the coke syrup back up and as I watching the system I see they coke comming out the drain tubes. I called Coke Smile number and get to tech support and was talking to a senior tech about what I saw and he said that it sounds like the tube that connects to the cold plate is damaged or that the cold plate is damaged for the coke line.
    He had me disconnect the coke line from the cold plate and cap it off and see if it still had a problem so that the front counter would have coke. He said that the only way to fix a cold plate is to replace the whole system. Is that correct?
    Sep 2011
    Fayetteville, NC
    I have seen the coldplate bypassed entirely. It was on a servend so I am not sure if you can do that on a cornelius. I do believe that it is possible though. For some reason I believe that they use 1/4 line coming out of the cold plate. It may be possible to extend the 3/8 beverage line and use a 3/8 by 1/4 and connect the two. I am 100 percent sure it will affect the brix. So you will need to check that.
    The only other options would be a fountain replacement.
    Jul 2012
    North west Arkansas
    If you break down and take this apart, please take a few pics and share, I'd like to see what I may get into sometime..
    Jul 2012
    Everett, WA
    I spoke with someone at Cornelius and he said yes the cold plate is able to be replaced with out replacing the whole unit, not sure when the bosses will get to ordering the new cold plate, so I will take pictures if I'm involved in the changing of it.
    Jul 2012
    North west Arkansas
    That would be great,,
    Sep 2011
    Fayetteville, NC
    Man you have some work ahead of you. I really would like to hear back from you the total manhours on this job.
    Jul 2012
    las vegas, nevada
    it seems like you got 2 choices. 1 find a line that is not being used connect your coke line to the one not being used and switch you coke decal. 2 is replace the unit
    Jun 2011
    wi
    Does your location use a multiplex chiller or a backroom package? If you have a multiplex then ypu could tap into the coke in the chilled bundle and run that to the abs after the cold plate
    Jul 2012
    Everett, WA
    This store doesn't have the multiplex in it like the other stores do. This store is in a rest stop with Pilot, and Subway.
    Jul 2012
    las vegas, nevada
    isn't ABS systems made specially for McDonalds? this is the automated beverage system from a pc you punch what kind of soda you want and it'll make it for you right?
    Jul 2012
    Everett, WA
    That would be correct, it is connected to the POS system. Cornelius called the boss and it sounds like this has happened before but it doesn't happen very often.
    Quote Originally Posted by flukillo View Post
    Jul 2012
    Everett, WA
    The cold plate will be being replaced next Monday morning at 12am
    Dec 2011
    Michigan
    You're a better man than I. As soon as they pointed to the ABS machine I would have told them to call there coke distributor
    Sent from my amazing 4G device
