Results 1 to 12 of 12
Thread: whats going on with my system
08-24-2006, 04:44 PM #1
- Aug 2006
- san antonio
- 5
i installed my system about four weeks and it was running fine. my pressures were 72 over 230 and had a good super heat and sub.cool. well, latey i've notice that my t-stat wasn't dropping temp.So i checked my pressures and now i have 55 over 200. At first i thought i had a leak but when adding freon my pressures stayed the same,Freon goes in but my pressurs go back.Im thinking i have a restriction at my txv. (please help)
08-24-2006, 04:56 PM #2
Re: whats going on with my system
Might want to check if your coil is froze up or ice on it, you can put 30# of freon in a system that is froze up, did you install this yourself? are you a tech? if not with a brand new system I would make a call for help to a service tech. before you damage something.Originally posted by service roy
now i have 55 over 200. At first i thought i had a leak but when adding freon my pressures stayed the same, (please help)“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
08-24-2006, 05:03 PM #3
- Aug 2006
- Phoenix, AZ.
- 38
Sounds like you may still have a leak. Did you pull a vac on the system and use a micron gauge when you installed it?
08-24-2006, 05:10 PM #4
- Aug 2006
- 173
[Edited by jim baughman on 08-25-2006 at 04:13 AM]
08-24-2006, 05:41 PM #5
Due to Site Rules we are not allowed to discuss "step by step" or "technical issues" in this area.
If you are a professional in the HVAC/R Field, please register as a Professional Member.
Provide some general information in your profile. This way we can discuss this matter in the Pro-Forums.
After you register as a Professional, we’ll move this post over to the ProTech Forum.
Thanks!
08-24-2006, 05:45 PM #6
- Jan 2005
- Perth - Western Australia
- 775
Pulla who? micron isnt that a computer ?Originally posted by waynesrefrigeration
Sounds like you may still have a leak. Did you pull a vac on the system and use a micron gauge when you installed it?The Captain.
08-24-2006, 08:19 PM #7
Professional Member*
- Jul 2000
- Northern Wisconsin
- 1,566
Pressures don't mean much without knowing the temperatures and conditions the unit is operating in. If all conditions were exactly the same your pressures should be the same
08-24-2006, 10:09 PM #8
- Aug 2006
- san antonio
- 5
found problem
well guys, i fixed the problem, it was the txv.It wouldn't open all the way.Now its running like a true champ. Thank you very much for information.
08-24-2006, 10:37 PM #9
So how much crap was on the inlet screen???
08-24-2006, 11:05 PM #10
- Aug 2006
- Phoenix, AZ.
- 38
Yeah, let's all give Roy an atta-boy! LOL!
08-24-2006, 11:09 PM #11
Re: found problem
Did you strap the bulb to the liquid line to make it open up?Originally posted by service roy
08-25-2006, 07:10 PM #12
- Aug 2006
- san antonio
- 5
sometimes
there was not a screen in the txv, sometimes txv's are design only for the stem to be open half way.Why, i don't know. any suggestions?
