ytk6d5f2 need help
to manually turn on purge pump set for 30 per hr but hasnt run
hasn't purged or hasn't run? is the chiller running?
hasnt purged, chiller is running
Please describe the problem.
You cannot "turn on" a York purge. Setting the "number" to 30 is a setting to show an alarm if the purge count reaches 30 in one hour (after the first hour of chiller runtime). A York turboguard purge works only when the chiller is running.
Is this a single line panel?
perhaps there isn't any air in the chiller to be removed...that would be a good thing.
need help, someone that knows
that would be good if there is no air, but man that thing can really do some surging at times
Air is not the only thing that can cause surging.
The purge pump has to be working when the chiller is in operation, when you start it check the purge pressure max. 90 psia. and then purges.
- You may not post replies
- You may not edit your posts
Forum Rules
