Thread: turbo torch
    can you solder copper refrigeration lines with a turbo torch using mapp gas
    rick
    chicago suburbs
    yes............i can. but i'm pretty good.
    FILL OUT YOUR PROFILE!!
    knoxville ,tn
    I have before it worked fine,but I heard it can over heat o-rings,shrader valves,etc.You would'nt think it's true,considering it does'nt get as hot as acy & oxg,but you have to leave heat on longer.I would use a good heat shrink if thats all you have.
    Phoenix, AZ.
    Thumbs down
    works ok on the small lines, but not very good on larger lines, compressor stubs, and service valves.
    Washington
    Up to about 3/4" it does OK. Any bigger and it basically just turns the brazing compound to sludge.
    Jun 2006
    The turbo torch has two nozzles. Without a curved handpiece it's difficult to maneuver quickly. I'd say the joint needs to be very out in the open.
    Is it hot enough, yes. Is it wide enough - maybe. Will you be happy with it - not likely.
