Results 1 to 13 of 23
Thread: R410 Refrigerant Recovery
07-25-2012, 08:55 AM #1
- Jun 2012
- Puerto Rico
- 10
I am buying a new recovery machine, which would you recommend?
07-25-2012, 09:15 AM #2
I picked up the Appion G1 (not the G5 twin) for under $500 this spring. It works awesome, and is small enough to fit on the van full-time without being in the way. More than enough for residential stuff.
07-25-2012, 10:28 AM #3
- Jun 2012
- Puerto Rico
- 10
I will use the equipment for light to heavy commercial use. I needa reliable equipment for every refrigerant. Thanks
07-25-2012, 04:27 PM #4
Appion G5 all the way. Use all the time light to heavy commercial. Fast and reliable. Not to heavy and compact. Works even quicker if you pull the valve cores. Go to appion web site to see some nice videos. Hope this helps.
07-25-2012, 07:54 PM #5
- May 2011
- Oklahoma
- 287
G5 Twin. Quit looking at others and trust us, you won't be dissapointed.
07-25-2012, 07:56 PM #6
Appion G5. Not too heavy, great piece of equipment.
07-25-2012, 07:58 PM #7
- Jun 2012
- Puerto Rico
- 10
Thanks!!!!
07-26-2012, 01:10 PM #8
- Jul 2012
- Phoenix
- 29
Appion for sure
07-26-2012, 06:51 PM #9
- Jun 2012
- Fayetteville, NC
- 116
Def the appion. Last company i worked for had the g5, pull the cores and it will make quick work on resi system. I have the g1 now. not quite as good as the g5 but still better than other brands and is priced very well for the quality.
07-26-2012, 10:33 PM #10
- Jun 2012
- Puerto Rico
- 10
Thanks for the advice bougth the G5 today no regrets.
07-28-2012, 01:51 AM #11
07-28-2012, 08:31 AM #12
Read the directions and understand your machine. It will pump liquid pretty fast in or out of the machine. Have to throttle down when pumping back in to stop from slugging. Like said before,pretty good vids out there. Congrats on your purchase.
07-28-2012, 09:31 AM #13
We had to change a mini split on a roof with no outlets. It was a weird situation had an electrician there who got us outlet wired. We hooked up and shortly after saw the magic smoke and shut it down. I tested voltage on outlet and found 220. We grabbed a diff unit to finish, but a few months ago I tried the g5 and it still worked lol, just not as good. Still haven't figured out a good way to tell my boss. Must be a tough unit.
